Random but persistent imperfections
(10-16-2020, 04:45 PM)HLing Wrote: Then while installing, it said that the software is not for arm64 structure. I'm confused as far as what exactly I can use. Am I wrong in assuming that something .deb is compatible with the Pine phone?
Yes unluckily you are wrong. There is a lot of software which is compiled for an Processor architecture and only run on CPU's with compatible instruction set. There are ways around but the aren't easy to go. Like de compiling and recompiling for the given architecture or emulating the architecture the software is compiled for. Even then it isn't said that skype would work on the Pinephone. As example, I am sure they require some sort of Digital restriction management which I am not sure the Pinephone Hardware supports.
Random but persistent imperfections - by HLing - 10-16-2020, 04:45 PM
RE: Random but persistent imperfections - by cybercow - 10-17-2020, 05:42 AM
  Make scale setting persistent 3x5co 2 2,217 10-26-2021, 05:57 PM
Last Post: 3x5co
  Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build? LibrePhoneUser 3 4,057 01-17-2021, 12:44 PM
Last Post: LibrePhoneUser
  wi-fi mac-address random chris_02 8 9,232 07-05-2020, 11:35 AM
Last Post: bingo600
