Unsatisfactory GPS reception on PinePhone?
(10-01-2020, 05:30 AM)LinAdmin2 Wrote:
(09-30-2020, 12:21 PM)wibble Wrote: It's hugely better if you use AGPS, which pretty much every smartphone does most of the time. If you're using Mobian you can try the proof of concept python script to fetch the AGPS data and load it into the modem:
https://gist.github.com/alastair-dm/2632...e555fa6628
Thanks for this help. With AGPS I got a fix within a few minutes and GPS reception works as expected Wink
Just wanted to report I am unable to get a fix on my new pinephone manjaro ce edition.
I've installed the updated modem firmware from https://forum.pine64.org/showthread.php?tid=11815 so I have "EG25GGBR07A08M2G_01.002.07"
As well as the AGPS fix mentioned in this thread as can be seen from the assistance server output in the console output I've included below.
[root@manjaro-arm ~]# mmcli -m 0 --location-status
  Location |        capabilities: 3gpp-lac-ci, gps-raw, gps-nmea, agps-msa, agps-msb
          |              enabled: 3gpp-lac-ci, gps-nmea
          |              signals: no
  GPS      |        refresh rate: 5 seconds
          | supported assistance: xtra
          |  assistance servers: http://xtrapath1.izatcloud.net/xtra3grc.bin
          |                      http://xtrapath2.izatcloud.net/xtra3grc.bin
          |                      http://xtrapath3.izatcloud.net/xtra3grc.bin
[root@manjaro-arm ~]# mmcli -m 0 --location-get
  3GPP |      operator code: XXXX
      |      operator name: XX
      | location area code: XXXX
      | tracking area code: XXXX
      |            cell id: XXXXXXXX
  GPS  |              nmea: $GPGSA,A,1,,,,,,,,,,,,,,,,*32
      |                    $GPRMC,,V,,,,,,,,,,N*53
      |                    $GPGSV,3,1,10,01,,,,02,,,,03,,,,06,,,,1*61
$GPGSV,3,2,10,10,31,210,,12,33,042,,15,,,,16,,,,1*62
$GPGSV,3,3,10,17,,,,18,,,,1*6A
      |                    $GPVTG,,T,,M,,N,,K,N*2C
      |                    $GPGGA,072623.52,,,,,0,,,,,,,,*4D
I've tried waiting for a number of hours and based on what I can understand from the output on the GPGSV line it looks like it's tracking 10 satellites with varying degrees of signal strength. I'm unsure why it's unable to get a fix though.
Is anyone else having difficulties, or does anyone have any other tips?
Thanks!
RE: Unsatisfactory GPS reception on PinePhone? - by sog8b - 11-27-2020, 01:31 AM
  my pinephone melted norayr 6 931 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,111 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 727 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 366 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,873 02-05-2024, 03:17 PM
Last Post: wigan
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,414 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,023 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,177 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,496 07-23-2023, 03:49 PM
Last Post: kb-zealot
  Using optical drives with Pinephone cdforever 2 1,221 07-18-2023, 01:28 PM
Last Post: cdforever
