Best quick/easy way to control case fan speed?
(06-22-2021, 07:00 AM)Mrfixit2001 Wrote: https://github.com/mrfixit2001/Rock64-R64.GPIO
https://github.com/tuxd3v/ats
I use ats to control the case fan in my RockPro64, it works fine. I've also just manually set the fan speed with e.g.
   echo 50 > /sys/devices/platform/pwm-fan/hwmon/hwmon3/pwm1
(You must be root of course)
edit: just realized this thread is about Rock64, not RockPro64...
RE: Best quick/easy way to control case fan speed? - by hyc - 06-23-2021, 09:20 AM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 635 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,330 01-15-2023, 10:36 AM
Last Post: ds00
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,551 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 16,641 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 15,880 07-07-2021, 05:50 AM
Last Post: Rocklobster
  Configuring Python GPIO Pin Control Rock64 www139 3 7,701 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 2,988 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 16,152 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 5,941 06-23-2019, 08:00 AM
Last Post: rasputin
  low speed wifi pas059 4 5,277 05-13-2019, 12:09 PM
Last Post: pas059
