Rock64's temperature while being in aluminium case
I am about to order from pine64 website these : 1 Rock64 4GB, 1 EU power supply, 1 heatsink and 1 "Model B" premium aluminium casing.
I wonder how the Rock64 is doing while being locked up that aluminium case as I don't see any openings. Is this casing effective at keeping the Rock64 cool (or not too warm ^^) ?
Anyone to shut my concerns down ? Smile
Thanks a lot Smile
(04-17-2019, 01:29 PM)_zernok Wrote: Hello,
Thanks a lot Smile
Hi _zernok, hi forum!
I recently purchased a Rock64 (4GB version) and a "Modell B" Premium Aluminium Casing. I successfully installed DietPi (downloaded from https://dietpi.com/) on a 16GB eMMC. Unfortunately, the SBC crashes occasionally with a kernel panic.
I assume the cause is a thermal problem. I used the tool stress and could reproduce the failure. With low load, the Rock64 runs stable for days.
I tried to catch the kernel panic message, but I have currently no sufficient UART level converter at hand that is fast enough for the 3 Mbaud serial console of the Rock64 (only a CP2102-based one). This way, I hope to get some information which point to the root cause of the kernel panic.
The cover of the casing features a "L"-shaped "heatpipe" inside that attaches to the SOC and memory chip of the Rock64 via a thermal compound. Hence, there is no simple way to attach an additional heat sink to the Rock64 inside the casing.
Does anyone have/had the same problem and an idea how to fix this?
Thank you in advance!
Regards,
rasputin
Thanks a lot Smile
Regards,
rasputin
with proper thermal compound on the L-shape heatpipe and ROCK64 SoC surface, the heat should be able distribute to whole Aluminum case.
(06-23-2019, 12:46 AM)tllim Wrote: with proper thermal compound on the L-shape heatpipe and ROCK64 SoC surface, the heat should be able distribute to whole Aluminum case.
Hi tllim!
For a picture from my Rock64 inside its housing see here: https://pasteboard.co/IkKDeQI.jpg
You see: The thermal compound shipped with the casing is attached underneath the heatpipe.
I monitored the temperature when appling load to the SBC (running stress -c 4 -m -t 5m), and the temperature stayed well below 80°C.
The crashes I see may not be linked to a thermal problem. I opened a thread in the DietPi forum.
Regards, Jan
  Are HW design files available for ROCK64? irenek 3 4,685 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 316 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,036 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 608 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,160 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,708 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,469 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,572 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,408 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 6,953 09-28-2021, 03:07 PM
Last Post: TRS-80
