Copy To SD Card, All I get Is Red Light & Black Screen . . . .
(09-04-2020, 09:37 AM)bcnaz Wrote: September 03 Mobian nightly build,  Booted first try on my new PMOS Convergence Pkg phone (3gb ram)
Simply download and then flash with Balena Etcher,  I also use 'resize' from 'Disks' to use the whole 32gb SD card. (after flashing the card)
Plug it into the new phone and it starts right up.
There is a start page after you fire it up, but that sometimes is several minutes after you see the desktop screen.
It seems to run a bit faster after a few reboots.
Note:  In settings, be sure to go to 'Regions & Language' and set all the settings there. (you will have to manually restart after doing those settings)
Good Luck
I have 2 of the Convergence Pkg (3gb ram) phones, currently I have Mobian (September 03 nightly build) on one and the factory PMOS on the other.
 Both are doing OK, I only have a sim card in the PMOS at the moment, and data is working on that one.
I'll edit above comment, Mobian is a GO !!!
Arch is a GO !!
PureOS is a NO !!
I'm SO SO hoping UBports gets this #GB thing worked out. That's what I wanted to see Shy
RE: Copy To SD Card, All I get Is Red Light & Black Screen . . . . - by NobodyNew1 - 09-04-2020, 10:45 AM
  file manager vs. SD card laserpyramid 6 5,836 10-18-2021, 03:10 AM
Last Post: acrux
  Screen-off = dead phone okgo 11 9,871 09-27-2021, 07:53 PM
Last Post: jtn0514
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 4,990 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
Sad Help! - Screen blank after update. Zweitaktmotor 4 4,560 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  noticable Screen flicker KNERD 0 2,071 01-13-2021, 09:00 PM
Last Post: KNERD
  Automount SD card MasterGreenbolt 7 10,792 08-16-2020, 05:40 AM
Last Post: FOSSagent0
  Is bluetooth lag for A/V playback due to SD card? Cree 1 2,785 08-02-2020, 06:30 PM
Last Post: hiimtye
  Black screen after pine64 logo Putergenius 2 3,505 07-21-2020, 05:15 PM
Last Post: natasha
  [Possible solution] Stuck on blank screen kugiigi 4 5,900 06-29-2020, 02:51 PM
Last Post: rocket2nfinity
  Booting from SD card bingo600 1 2,772 06-20-2020, 02:33 AM
Last Post: bingo600
