Battery/wifi problems every time I take the battery out to change SIM or SD card
(08-23-2020, 05:18 PM)bcnaz Wrote: I have not had this problem, I have had my battery out for sd card swapping a lot of times !
Since the problem does eventually go away,
perhaps the phone or battery contacts have something on them.?
Could try carefully cleaning the contacts ?
Just gave them a good clean with an alcohol wipe and put the battery back in and it booted right up without being on the charger.  I totally did not think that would work but there must have been just enough residue left from the tape when it came from the factory. This will make trying new distros so much less of a pain.
Thanks so Much
RE: Battery/wifi problems every time I take the battery out to change SIM or SD card - by BlunderingBushcraft - 08-24-2020, 07:05 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 607 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 1,615 08-27-2023, 07:53 AM
Last Post: aular
  Battery life improvement freelectro 10 3,500 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,584 03-20-2023, 12:54 AM
Last Post: bcoyle
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,476 01-29-2023, 12:20 PM
Last Post: skandigraun
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 4,589 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,169 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,445 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 6,885 08-11-2022, 01:01 PM
Last Post: auanta
  Power supply vs battery albafrati 11 4,811 06-22-2022, 06:04 PM
Last Post: albafrati
