PBP won't boot (no amber or green LED)
#39
>don't update it if you can at all avoid it
I strongly suggest the kernel/uboot update, icon next to time (rock login)
Or mrfixit_update.sh (which is same)
The mrfixit distro is good for another reason than recovery,
it is 64 bit kernel and 32 bit userland, so if you need to run something only armhf.......
--more--
>Pressed power button 60+ seconds (very firmly) multiple times. No response.
After the long (20+s) press, let up, then a regular 1-2s start press,,, a quick tap is not enough
Sometimes it just need a hard power-off (7-8s),, not a hard reset (20s)
So, always, first try a hard power-off, and then if it does not work a hard reset (with good media)
RE: PBP won't boot (no amber or green LED) - by wdt - 04-13-2021, 05:20 PM
  upgrading u-boot--what version? where to get it? bsammon 0 34 Yesterday, 05:59 PM
Last Post: bsammon
  uboot wont boot to SD card after upgrade jbradley419 7 1,001 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 333 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,397 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 782 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 649 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,278 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 2,000 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 832 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 2,044 06-14-2023, 07:20 AM
