PBP won't boot (no amber or green LED)
#35
>I am not sure what you mean by this: (obviously the 'bad' uboot MUST be removed first)
Wherever your failed,, wrong arch write went to,,,likely emmc
(In my case, 10 months ago, I removed SD, but it was still dead, until 20s press)
So, remove or disable (note, instructions are a bit backwards, unless it has been corrected)
(enabled = switch enabled = shorted = emmc has no clock = emmc disabled)
Easier to remove, no confusion possible
Even if it is removed, you may have to do 20s press,, somehow it remembers bad config
(or disconnect battery for ?? _ 1 hour _ ??)
RE: PBP won't boot (no amber or green LED) - by wdt - 04-12-2021, 10:36 AM
  upgrading u-boot--what version? where to get it? bsammon 3 93 3 hours ago
Last Post: Pavlos1
  uboot wont boot to SD card after upgrade jbradley419 7 1,013 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 334 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,432 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 789 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 652 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,291 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 2,018 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 835 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 2,054 06-14-2023, 07:20 AM
