earpiece sound setting
I use pinephone Brave Heart edition with mobian as daily phone. It nearly works fine for my use. Thanks a lot for mobian !
I still have an issue to set correctly the volume of the ear piece. When I set it whith alsamixer or phosh settings, the value is sometime changed (during reboot for instance).
In alsamixer, master is at 100%, and earpiece at 100%. It is too much for my earpiece that is sounding very bad, making phone call difficult to hear because volume is too high with a lot of cracks. The range where the sound is ok is very small compared to the setting range in phosh settings. If I change the values in phosh settings and make a test of earpiece and go back to alsamixer, those values are back again to 100%.
I don't know which part of the software is storing the sound settings, I guess, it is not alsamixer. So if you can explain me how it is dealt with, I would be extremely gratefull.
Is there a way to avoid sound setting changes if not manually applied by the user ?
Thanking you in advance for your help !
* PinePhone BraveHeart Edition
earpiece sound setting - by Gobelin - 08-12-2020, 05:39 AM
RE: earpiece sound setting - by bcnaz - 08-12-2020, 09:32 PM
RE: earpiece sound setting - by wibble - 08-13-2020, 12:27 PM
RE: earpiece sound setting - by Gobelin - 08-13-2020, 01:46 PM
  Sound : notifications freelectro 6 1,953 06-07-2023, 01:03 AM
Last Post: freelectro
Exclamation No sound anonymous 22 9,053 11-08-2022, 09:07 AM
Last Post: dante404
  Date & Time-setting app is a very poor design treebeard 6 3,385 07-27-2022, 06:35 AM
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 2,743 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 1,076 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 3,348 12-27-2021, 05:40 AM
Last Post: Anna
  Mobile network mode setting not saved Zebulon Walton 3 3,073 12-05-2021, 12:12 AM
Last Post: bcnaz
  Setting up Mullvad to run on Mobian Azathoth 2 2,152 11-09-2021, 01:03 AM
Last Post: j4n3z
  Make scale setting persistent 3x5co 2 2,181 10-26-2021, 05:57 PM
Last Post: 3x5co
  Re-do First Time Setup / Location Services Setting (How?) calinb 3 4,023 01-01-2021, 08:03 PM
Last Post: calinb
