PBP not booting screen blank after SD card boot
(07-28-2020, 01:23 PM)belfastraven Wrote:
(07-28-2020, 08:58 AM)Jakobp Wrote: Hey there. I hope I can get a bit of inspiration for further problem shooting for my seemingly dead pbp. LEDs turn red then green(solid) as expected but screen doesn’t turn on at all. All worked perfectly until I wanted to test Manjaro i3 from SD card. I have Manjaro KDE  on eMmc installed already. Ok booted Manjaro i3 from SD card all worked fine. I updated this distro installed a few things from repository and built Vivaldi browser from AUR using Parmac. Then when rebooting I got the issue above. I thought there was something wrong with SD card and ejected and re booted only to see same issue with my installed system - nothing boots. I tried to charge in full then let it go completely flat in case of some endless sleep cycle ( this took about 20 hours). Any suggestions why the screen is just completely black? I know very little about things like gpu etc. so don’t know if any faulty hardware is preventing something to start screen? I’m really at a loss - I haven’t touched the hardware inside I have only flashed a card. SD card 32 gb and worked fine when I had Debian and Manjaro KDE on card. Any ideas??
 If you are seeing the green light,  the machine may very well have booted,  but has some kind of display issue. As a first step have you tried re-writing the sd card with the Manjaro i3 that originally did boot and trying to boot from that?    IF that works you know it's a software problem...
Also,  have you tried using the f2 key to turn up the brightness?  ..in case somehting in the update turned it down......
 I'm assuming you don't have a serial cable.  it's very helpful to have serial output at times like this.   You can watch the booting sequence and usually can see where the system is hanging or failing.  Often,  if its something like a software display problem, you can fix it....
Thanks for this - I tried both Manjaro i3 and Debian but same result. Will keep trying for a bit and then resort to console connection
RE: PBP not booting screen blank after SD card boot - by Jakobp - 08-12-2020, 02:58 AM
  unable to boot after manjaro update gega 6 3,308 10-28-2022, 01:18 PM
  PBP booting but stops at flashing power led jonasd 13 5,669 09-26-2022, 12:17 AM
Last Post: jonasd
  128GB Module not booting on 2022 Pinebook Pro batch JessicaQ 0 1,092 08-12-2022, 06:41 AM
Last Post: JessicaQ
  Malfunction: horizontal white streak on the screen regivanx 0 987 06-23-2022, 12:59 AM
Last Post: regivanx
  Troubleshooting of pinebook Pro red light and black screen wangyukunshan 0 1,766 03-23-2022, 12:10 AM
Last Post: wangyukunshan
  I broke my screen :( espenbo 3 3,072 01-03-2022, 03:46 PM
Last Post: altacus
  Broken Screen vxzero 0 1,385 08-26-2021, 09:02 PM
Last Post: vxzero
  Write to an A1-rated Micro SD card failed dsimic 12 11,659 07-28-2021, 11:38 AM
Last Post: dsimic
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 4,493 04-02-2021, 06:45 PM
Last Post: tkudog
  Minimum daughter boards/peripherals required for main board to boot cmicallef 5 4,715 03-12-2021, 10:10 PM
Last Post: cmicallef
