SDXC card prevents power on
It seems the boot sector of your card hasn't been deleted.
I would try:
Back up your sd card contents, then make sure you select the right device on the of parameter as this will delete the MBR and the selected device won't be able to boot anymore.
dd if=/dev/zero of=/dev/yoursdcard bs=446 count=1
The contents of your sd card shouldn't be deleted, but better safe than sorry.
SDXC card prevents power on - by hiimtye - 07-24-2020, 12:09 AM
RE: SDXC card prevents power on - by fernando_c_m - 07-24-2020, 12:51 AM
RE: SDXC card prevents power on - by hiimtye - 07-24-2020, 03:14 AM
RE: SDXC card prevents power on - by fernando_c_m - 07-24-2020, 04:40 AM
RE: SDXC card prevents power on - by hiimtye - 07-24-2020, 05:04 PM
RE: SDXC card prevents power on - by fernando_c_m - 07-24-2020, 11:55 PM
RE: SDXC card prevents power on - by hiimtye - 07-25-2020, 12:41 AM
RE: SDXC card prevents power on - by hiimtye - 08-15-2020, 05:05 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 593 02-17-2024, 04:15 PM
Last Post: vortex
  Pinephone - broken power button rorus 10 9,404 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,577 03-20-2023, 12:54 AM
Last Post: bcoyle
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,417 01-29-2023, 12:20 PM
Last Post: skandigraun
  Power supply vs battery albafrati 11 4,785 06-22-2022, 06:04 PM
Last Post: albafrati
  Pinephone won't boot from SD card arkadione 3 3,513 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 2,065 01-08-2022, 06:01 AM
Last Post: zooidic
  Power consumption during the call some_pinephone_user 0 1,166 10-29-2021, 06:03 AM
Last Post: some_pinephone_user
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,316 10-20-2021, 09:40 AM
  on off power button stopped working dcinoz 3 2,629 09-01-2021, 03:26 AM
Last Post: dcinoz
