[split] U-Boot with NVMe support, keyboard & display working
#52
(07-29-2020, 02:40 PM)as400 Wrote: @samueldr has identified the problem with booting later kernels. You can find details here --> https://github.com/samueldr/wip-pinebook...-664046551
Following this, here's a patch to Linux that should address the hang on kernels 5.6 and newer when video is enabled in U-Boot, by fixing the issue with the Rockchip PWM driver instead of undoing other changes to the kernel. (I don't use Github so I'm sharing it here.)
I've tested this using Guix and Linux 5.8.1 and it appears to work fine, but I'd be interested in hearing other people's experience with it on other kernel versions.
.txt   0001-pwm-rockchip-Keep-enabled-PWMs-running-while-probing.patch.txt (Size: 1.72 KB / Downloads: 317)
RE: [split] U-Boot with NVMe support, keyboard & display working - by simonsouth - 09-18-2020, 12:49 PM
  uboot wont boot to SD card after upgrade jbradley419 7 980 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 327 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,372 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 778 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 640 11-22-2023, 11:47 AM
Last Post: fxc
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 794 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,270 09-19-2023, 08:48 AM
Last Post: dachalife
  Dead Pinebook Pro Keyboard Keys calinb 2 1,110 09-02-2023, 12:31 PM
Last Post: calinb
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,982 08-03-2023, 03:30 PM
  power on Pinebook Pro mainboard without keyboard? papable 0 868 07-20-2023, 11:06 PM
Last Post: papable
