[split] U-Boot with NVMe support, keyboard & display working
#30
(07-29-2020, 02:40 PM)as400 Wrote: @Arwen to answer your questions:
- Problems with 5.5 and later - very plausible.
- It has booting from everything possible - eMMC, SD, USB and NVME
Let's wait and see how it goes for others.
@samueldr has identified the problem with booting later kernels. You can find details here --> https://github.com/samueldr/wip-pinebook...-664046551
Strangely I have booting problems just occasionaly. And with this last update from Arnaud it happens very rarely.
I am also having problems booting Manjaro with 5.7 kernel.  (on my NVME) but never  a MRfixit image ( from sd )with an earlier kernel.  When I can't boot, the system starts booting but gets stuck in the same place as it did before the latest changes.  The screen get a weird multi-color pattern and then nothing.  The serial console will also hang at that point.
The booting of different kernels on same device seems to be working fine (I faked it out by pointing to the same kernel with different menu names,  since I have only one on the device...)    I have noticed that when using CTRL-c to interrupt u-boot to boot from a different device,  there is no entry for the NVME  ,  so that if there is an SD card installed one will boot from that,  since it is specified before NVME in the u-boot code.boot order...
RE: [split] U-Boot with NVMe support, keyboard & display working - by belfastraven - 07-29-2020, 06:50 PM
  uboot wont boot to SD card after upgrade jbradley419 7 975 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 327 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,372 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 778 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 640 11-22-2023, 11:47 AM
Last Post: fxc
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 793 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,268 09-19-2023, 08:48 AM
Last Post: dachalife
  Dead Pinebook Pro Keyboard Keys calinb 2 1,110 09-02-2023, 12:31 PM
Last Post: calinb
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,982 08-03-2023, 03:30 PM
  power on Pinebook Pro mainboard without keyboard? papable 0 868 07-20-2023, 11:06 PM
Last Post: papable
