[split] U-Boot with NVMe support, keyboard & display working
(07-16-2020, 05:36 PM)belfastraven Wrote: Re testing:
@as400 ,  I am booting to where I get output on the PBP screen post u-boot,  occasionally.  U-boot output seems to work fine,  and I can use, e.g.  the return key, to interrupt it on the PBP,  but with the menu-version, ctrl-c is not bringing up the menu on the pbp.  It does however bring up the menu on my picocom serial session.
  I always do get the green light that indicates manjaro is booting,  but often see no output either on the pbp or the serial console.  Often I'll see either nothing or a multicolored "plaid" flash pattern on the entire screen ...
I'm only testing booting the nvme from spiflash,  since  that's the only device I have in the pbp right now--I never use the emmc  and use the SD card only to test various builds.
I attached serial logs  (with my comments interspersed) for several tries.
I reinstalled the pcm720   version of spiflash for now,  since that boots for me with no problems.  Once again,  this is on a Manjaro system with 5.7 kernel using  unstable
(07-18-2020, 07:32 AM)freerk Wrote: Hello,
I have probably bricked my Pinebook pro.
I flashed the SPI device.
Without the desired result; booting from the builtin M.2 drive
When I put it on I only see the red power LED flash for half a second and then nothing.
The system-board is consuming power because its getting warm.
After a long pres of 15 seconds the board is off again; the board is getting cooler again.
I tried to clear the SPI chip with rkdeveloptool
But I get an error:
./rkdeveloptool db rk3399_loader_spinor_v1.15.114.bin  >>
The device does not support this operation!
Is there someone who knows how to repair this?
Freerk Jongsma
I do not know about the red flashing light, but I have recovered from a borked spiflash several times.  Note: I had to short the spi as my reset button stopped working.  Can you verify that the Pinebook Pro is in maskrom mode?  Instructions are here:  https://wiki.pine64.org/index.php/Pinebook_Pro_SPI
RE: [split] U-Boot with NVMe support, keyboard & display working - by mamboman777 - 07-18-2020, 08:55 AM
  uboot wont boot to SD card after upgrade jbradley419 7 980 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 327 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,372 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 778 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 640 11-22-2023, 11:47 AM
Last Post: fxc
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 794 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,270 09-19-2023, 08:48 AM
Last Post: dachalife
  Dead Pinebook Pro Keyboard Keys calinb 2 1,110 09-02-2023, 12:31 PM
Last Post: calinb
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,982 08-03-2023, 03:30 PM
  power on Pinebook Pro mainboard without keyboard? papable 0 868 07-20-2023, 11:06 PM
Last Post: papable
