07-16-2020, 05:36 PM
(This post was last modified: 07-16-2020, 05:40 PM by belfastraven.
Edit Reason: add attachment
as400 boot logs.zip (Size: 4.41 KB / Downloads: 341) Re testing:
@as400 , I am booting to where I get output on the PBP screen post u-boot, occasionally. U-boot output seems to work fine, and I can use, e.g. the return key, to interrupt it on the PBP, but with the menu-version, ctrl-c is not bringing up the menu on the pbp. It does however bring up the menu on my picocom serial session.
I always do get the green light that indicates manjaro is booting, but often see no output either on the pbp or the serial console. Often I'll see either nothing or a multicolored "plaid" flash pattern on the entire screen ...
I'm only testing booting the nvme from spiflash, since that's the only device I have in the pbp right now--I never use the emmc and use the SD card only to test various builds.
I attached serial logs (with my comments interspersed) for several tries.
I reinstalled the pcm720 version of spiflash for now, since that boots for me with no problems. Once again, this is on a Manjaro system with 5.7 kernel using unstable
