What should i pack in the box with my v2.2. clusterboard?
(07-19-2020, 03:03 PM)timoc Wrote: The battery question was more along the lines if anyone has a battery powered cluster board. I have been thinking about a portable cluster...
Mine is battery powered when (when it runs, that is!). Although that is battery power is from a fixed solar system + 12v supply. (I take 12v from the batteries, step it up to 24v till it gets to near where the clusterboard is, and then drop it back down to 12v at the clusterboard and power it via the terminal block. So not exactly portable. If I were to go portable, I'd either find a power bank that can output 12v (if I want a plug and play approach), or probably a 4S lipo pack, BMS and buck regulator to give a constant 12v if I want to go the DIY route.
RE: What should i pack in the box with my v2.2. clusterboard? - by pfeerick - 07-23-2020, 03:34 AM
  Managed Ethernet switch on the Clusterboard dsimic 6 5,571 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 5,974 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 1,660 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 12,786 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 5,322 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 2,107 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 23,550 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 3,858 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 7,418 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 6,283 08-15-2020, 07:31 AM
Last Post: poVoq
