[SOLVED] Red light flashes next to barrel-port
Hi All,
I’m experiencing similar symptoms to Carl.
I received the PBP yesterday, powered it up, used it for a couple hours and then plugged in the barrel plug charger. The OS acknowledged the machine was charging but the battery continued to discharge. I thought perhaps the power supply couldn’t handle powering the laptop and charging the battery simultaneously, which if true is a bit of pain, but one I can live with.
I got a bit carried away (new toy and all) and ran the battery flat, so I plugged it into the barrel plug charger to charge overnight. This morning I woke up to a laptop that was still completely flat. I stuck a meter across the battery and it’s hovering around 3v, so it clearly hasn’t taken on any charge at all.
When plugging in the by-pass cable, and powering from mains, the machine boots (or at least it did the second time…) and works as expected. So, I’ve raised a ticket with support, and I’m currently charging the battery on an external charger to see if the battery management system will spring to life with a fully charged battery.
Let me know if anyone else has experienced this or has any other suggestions for a fix.
Cheers,
Ron
RE: Red light flashes next to barrel-port - by FreeRangeRon - 07-14-2020, 05:41 AM
  Blinking Tiny Blue Indicator Light? ArchiMark 3 1,232 06-30-2023, 03:15 PM
Last Post: Samurai_Crow
  How are people finding the type-A USB 3.0 port? chris88233 1 1,011 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Fried the charger port and USB leapylee 1 1,611 01-12-2022, 03:32 AM
Last Post: Danct12
  Serial port cable bsammon 17 24,611 03-04-2021, 10:00 AM
Last Post: mattpenn
  power light blinking during charge when pbpro is off Idaho 0 1,815 01-04-2021, 10:53 AM
Last Post: Idaho
  Boot issue (red light) pineitup 10 10,148 11-01-2020, 11:26 PM
  Orange light no boot blues :) feoh 6 7,454 10-13-2020, 11:11 AM
  Charging via USB-C Port tyha 15 20,165 07-22-2020, 08:15 PM
Last Post: iscmob
  Orange light won't boot>>>PineBook Pro user1gokou 4 6,406 07-10-2020, 03:04 PM
Exclamation [SOLVED] PBP will no longer power on s3rvant 10 10,319 07-04-2020, 01:57 PM
Last Post: prokofiev
