Pinebook Pro Battery Mod Tips and Images
Unfortunately, this is a fairly standard mod for me so I didn't document it rigorously - I may add additional capacity in the future and will keep in mind to take more photos then. Feel free to ask specific details and I will do my best to describe them.
The battery was a random one I had in my collection of salvaged LiPos - model number PP045582AB - google says the dimensions are 137*45*4.1mm.
LiPos come in a variety of dimensions and depending on whether or not you are willing to cut away more of the plastic frame, you likely can fit larger ones as desired. The primary constraint is the narrowing of the enclosure towards the trackpad edge.
Personally, I wanted to keep all four screw-holes on the plastic frame intact as well as not obstructing the NVME mounting area.
Updated energy consumption statistics after one charge cycle since the mod.
.png   pbp_battery_mod_screenshot.png (Size: 114.09 KB / Downloads: 611)
RE: Pinebook Pro Battery Mod Tips and Images - by phuzy - 07-11-2020, 10:55 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 744 05-06-2024, 09:27 AM
  Lithium Battery Connector Franestra 0 156 04-02-2024, 01:52 AM
Last Post: Franestra
  Pinebook Pro on Debian 12 Power Issue u974615 1 379 03-13-2024, 10:46 AM
Last Post: u974615
  Bad replacement battery? chris88233 3 471 02-19-2024, 04:59 PM
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Bypassing the Battery gilwood 0 272 02-01-2024, 10:45 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 661 01-05-2024, 08:40 PM
Last Post: tomekdev
  PBPro Battery specification Perl6_user 3 644 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement battery for PineBook Pro DrYak 3 1,166 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 2,946 09-26-2023, 01:08 AM
Last Post: david-lechner
