Unable to send SMS on US Mobile GSM (T-Mobile MVNO)
I have just briefly had a look through the code.
What appears to happen is that chatty has no SMS protocol enabled at that time making the "+" button greyed out.
Presumably chatty does not "find" the modem on startup and therefore has no SMS support.
Could you try doing the following:
After boot wait a little bit to make sure the modem is online and connected to your carrier (I don't think you necessarily need to be connected - I could be wrong though).
then run "killall chatty" a few times until you get "no process found" and then start chatty again from the UI.
I have the suspicion that the "protocol detection" is only run once on startup and maybe it is during a time (since a daemon is autostarted)
where the modem is not yet "fully up". Obviously when you receive a new SMS chatty will then know that SMS work (if that makes sense) ;)
RE: Unable to send SMS on US Mobile GSM (T-Mobile MVNO) - by devrtz - 07-09-2020, 01:04 AM
  Mobile internet via cellular network mostly not working Anna 18 10,336 01-19-2024, 02:59 AM
Last Post: anonymous
  Unable to wake up from suspend xavi92 5 1,150 10-26-2023, 03:02 PM
Last Post: xavi92
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,110 07-07-2023, 03:29 AM
Last Post: jojuma
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,582 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,388 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,559 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 17,058 10-29-2022, 09:16 AM
Last Post: treebeard
  Unable to send messages with chatty user641 0 779 09-07-2022, 04:35 AM
Last Post: user641
  Amberol Mobile Music player(flatpak) biketool 0 936 06-19-2022, 07:16 AM
  sharing mobile data through usb tethering deb75 7 4,274 02-26-2022, 08:52 AM
