Amberol Mobile Music player(flatpak)
I have been using Lollypop since I started using my pinephone on Alpine/postmarketOS and it is also part of Mobian Phosh.
Lollypop is probably great if you spend the time learning how all of the add-ons work, it seems like a cool player but I think it has too many nonstandard options enabled by default.
I don't care to worry about extra functions, i was happy in the early 2Ks with a used Diamond Rio 500, volume, skip forward and back, pause, play and shuffle/order play.
I didn't need more and still really don't, XMMS(Audacious) with winamp skin is still my favorite desktop player.
If you consume music like this maybe Amberol is for you vs Lollypop.
Amberol requires your music dir every time(it includes your SD card) it loads so I dont think it has a .conf file, then it takes a few 10s of seconds to scan and be ready to play.
I assume Amberol is in early dev as it doesn't work well from the lock screen, skipping works but pausing removes the media control form the lockscreen and requires unlocking to access and restart play.
I feel like Amberol(once the lockscreen pause issue is solved) would be great for playing a directory over car bluetooth where interaction beyond pause and skipping is a safety issue.
A side issue, l wish that with all entertainment multimedia apps incoming telephone/VOIP calls app or the OS would trigger a multimedia pause command when ringing the ringtone for incoming calls.
  Mobile internet via cellular network mostly not working Anna 18 10,277 01-19-2024, 02:59 AM
Last Post: anonymous
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,576 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,383 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,552 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 17,040 10-29-2022, 09:16 AM
Last Post: treebeard
  Flatpak on Bookworm biketool 0 909 05-25-2022, 03:47 PM
  sharing mobile data through usb tethering deb75 7 4,273 02-26-2022, 08:52 AM
  Flatpak error during apt update user641 0 1,146 02-14-2022, 08:35 AM
Last Post: user641
  Reskinning Apps for Mobile biketool 6 3,437 12-05-2021, 02:30 PM
  Mobile network mode setting not saved Zebulon Walton 3 3,070 12-05-2021, 12:12 AM
Last Post: bcnaz
