Dallas 1-Wire Support
#31
(11-30-2016, 02:23 PM)martinayotte Wrote: You don't need to do modprobe, it should comes automatically.
Check you DTS again, use "gpios = <0x30 0x2 0x8 0x0 0x0 0x0 0x0>;", recompile the DTB, reboot, and recheck.
Otherwise, it must be a wiring problem.
I believe that gpio PC8 as in the DTS is pin 12 on the PI bus.  Try connecting the data line there instead of to pin 7.
Dallas 1-Wire Support - by ItsDave - 05-10-2016, 03:01 AM
RE: Dallas 1-Wire Support - by peterz - 05-10-2016, 04:37 AM
RE: Dallas 1-Wire Support - by ItsDave - 05-10-2016, 07:36 AM
RE: Dallas 1-Wire Support - by peterz - 05-10-2016, 08:00 AM
RE: Dallas 1-Wire Support - by martinayotte - 05-10-2016, 08:16 AM
RE: Dallas 1-Wire Support - by ItsDave - 05-10-2016, 08:42 AM
RE: Dallas 1-Wire Support - by peterz - 05-11-2016, 06:21 AM
RE: Dallas 1-Wire Support - by martinayotte - 05-10-2016, 08:59 AM
RE: Dallas 1-Wire Support - by ItsDave - 05-10-2016, 09:24 AM
RE: Dallas 1-Wire Support - by longsleep - 05-10-2016, 12:28 PM
RE: Dallas 1-Wire Support - by martinayotte - 05-11-2016, 07:24 AM
RE: Dallas 1-Wire Support - by longsleep - 05-11-2016, 04:02 PM
RE: Dallas 1-Wire Support - by martinayotte - 05-12-2016, 07:09 AM
RE: Dallas 1-Wire Support - by martinayotte - 05-29-2016, 03:49 PM
RE: Dallas 1-Wire Support - by tllim - 05-29-2016, 10:36 PM
RE: Dallas 1-Wire Support - by ed_mann - 11-26-2016, 04:18 PM
RE: Dallas 1-Wire Support - by martinayotte - 07-11-2016, 10:09 AM
RE: Dallas 1-Wire Support - by longsleep - 07-11-2016, 10:34 AM
RE: Dallas 1-Wire Support - by martinayotte - 07-11-2016, 04:23 PM
RE: Dallas 1-Wire Support - by ItsDave - 07-11-2016, 12:25 PM
RE: Dallas 1-Wire Support - by joey - 08-12-2016, 11:01 AM
RE: Dallas 1-Wire Support - by martinayotte - 07-11-2016, 08:08 PM
RE: Dallas 1-Wire Support - by martinayotte - 08-12-2016, 11:33 AM
RE: Dallas 1-Wire Support - by joey - 08-12-2016, 11:05 PM
RE: Dallas 1-Wire Support - by longsleep - 08-12-2016, 12:20 PM
RE: Dallas 1-Wire Support - by martinayotte - 08-12-2016, 01:48 PM
RE: Dallas 1-Wire Support - by martinayotte - 08-13-2016, 07:26 AM
RE: Dallas 1-Wire Support - by martinayotte - 11-27-2016, 03:39 PM
RE: Dallas 1-Wire Support - by ed_mann - 11-28-2016, 08:08 PM
RE: Dallas 1-Wire Support - by martinayotte - 11-30-2016, 02:23 PM
RE: Dallas 1-Wire Support - by Wom the Bat - 12-26-2016, 10:44 PM
RE: Dallas 1-Wire Support - by ed_mann - 12-27-2016, 08:30 PM
Question RGB LED Matrix support? foxnox 1 4,330 12-29-2017, 06:52 PM
Last Post: psychedup
  RaZberry Module (z-wave) need support to get it working! Luxus 13 19,129 11-03-2016, 02:04 AM
Last Post: Luxus
  USB WIFI Dongle Support InCognito 3 6,646 01-20-2016, 11:27 AM
