Announcing the Mobian project
(09-22-2020, 07:15 AM)fernando_c_m Wrote:
(09-22-2020, 06:14 AM)HLing Wrote: Something happening to the sound setting for sure. I was in full panic mode yesterday when I finally realized the sound was defaulting to Headphone settings, but at least I had options to switch to internal speaker and microphone.  Today, in the whole wound setting there was only "Dummy O"  option in the output device, nothing in the input device, nor configuration.  no choices. no sound.  Help! (by the way, just installed mobian-devtools, and also, still had to do the blacklist anx7688 to get my charging back to 1.5A again.)
Try updating again. The dummy output was gone on my phone after updating and rebooting. It defaults to headset though, like yesterday.
Thanks, fernando_c_m.  I updated and rebooted. so now, for output there's "internal speaker" (works when i do the test but not when I make a voice call) , "Internal earpiece" and "headset".  I can only hear something when i plug in a wired headset, so I used it to check my voicemail. At the prompt for code I tried to enter it, but the numbers don't go through, even though it shows the numbers on my phone, and so i cannot check my voicemail.  I am stuck between a good sms mobile (Pine phone), and a good voice mobile (Nokia N9), but can't seem to have both.  I know Mobian is capable of it all because there WAS a sweet spot when everything worked. Just wonder what I did, or did not do since then that's causing this....
If you value stability, I would suggest only updating when a-way announces a new stable reference image.
 I do value stability, but my fallback is also unreliable. So can only look onward. By the way, today "Dummy O" was there initially, then somehow something morphed, (and under the cover of my pine phone was again emitting crackling noises...did I mention that yesterday?) and then the 3 options are back. still no regular voice call sound, but sms, internet and all are working.
My Brave Heart phone is running on the last stable Mobian release fairly dependable, That's my daily driver.
My PMOS phone is running Nightly Sept 23, it sends SMS text but does not receive, it has inconsistent audio problems.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-23-2020, 01:24 PM)bcnaz Wrote: My Brave Heart phone is running on the last stable Mobian release fairly dependable, That's my daily driver.
Hi bcnaz, which is the latest stable Mobian ? sept 5? sept 21?
 Since I last post moments ago, (where I purged the Authenticator that I had never used but was on my UBport CE pine phone, and therefore I did not reinstall)  I'm happy to report my phone call abilities have returned.  I have to note that when I first tried to call out I had to manually change it from "default" to "phone call" for it to work.  After I hung up, I checked and saw that the configuration had gone back to "default." and watching this in setting, I used another phone to call my pine phone. Pine phone rang. I picked up. said something. Hung up. looked at Setting, the Configuration had switched to "phone call." Worthy of note is that in the past when I test in such proximity there'd be very loud echos. Today it is all normal sounding. Yay! The "headset" option is no longer there, back to "internal speaker" and "internal earpiece".
So, the Nightly Sept 23. on the UBPort CE  seem back to normal. my texts work both ways, too.
Thank you, Team!
You might have to clear your modem through CLI to keep receiving sms. When someone sends you mms messages the modem receives them but Chatty can’t process them so they sit in limbo on your modem and plug it up. After about seven or eight mms messages are received it only allows outgoing texts to work.
https://gitlab.com/mobian1/issues/-/issues/89 <— there is the fix for that issue. I’ve had to do it a couple times on Mobian so far
@LMalilil
You were correct,
But I used 'Modem Manager' to empty out the cache.
  Cleared out what appeared to be 10  mms
Then after a restart about 50  texts poured into the sms text app
  >  I had just flashed the Sept. 25 nightly release to sd card and still had no incoming text, so that told me you were correct.
                 Since the problem persisted across a completely new operating system.
   (a GUI user fix)
I have not tested everything yet,
but, So far testing September 25 Nightly Release has been Excellent ! !
Thank You Team Mobian
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
With recent update, I observed several improvements in Mobian. One of them is improved user experience for auto brightness control. Previously, if this option was active, the screen brightness got to 0% in several seconds. Now the auto control is a bit jumpy, but fully functional. Needless to say, with this change, the battery life is also greatly improved.
CURIOUS :
Is there an estimate on the date of the next "Stable Release"  ?
Thank you
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  atinout binaries for mobian/debian? NeutralGrey 2 103 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,787 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,140 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 170 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,130 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,904 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,178 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,964 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 662 07-05-2023, 03:57 AM
Last Post: paulcarton
