Announcing the Mobian project
I used the August 23 release all day, over-all it worked pretty well.
One time (of many successful uses) it would not open after suspend, had to do hard shut down and restart.
One time while writing a sms/text message it went to the log-in page.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
August 24 release :
  NO SOUND  !
  I put the August 23 sd card back in and still no sound  ?
I then reflashed the August 23 sd card and everything seems ok now.
         Huh
(08-24-2020, 07:11 AM)bcnaz Wrote: August 24 release :
  NO SOUND  !
         Huh
no reflashe, the libasound2 downgrade fixed this problem : https://gitlab.com/mobian1/issues/-/issues/78
Is there a way to switch off CRUST?
The other day I was calling the phone and it started to wake up, but didn't finish until the ringing stopped and there was no notification of a missed call. I think this deep sleep stuff is missing the point here.
(08-26-2020, 01:28 AM)cefre00 Wrote: Is there a way to switch off CRUST?
Go to settings --> power, at the bottom you can set if and when it goes to standby.
Thank you, good stuff. Wink
Strange, With the August 30 nightly I can receive calls, but I cannot call out ? .. ?
(08-30-2020, 07:41 AM)bcnaz Wrote: Strange,  With the August 30 nightly I can receive calls, but I cannot call out ? .. ?
Same here. Which carrier do you have ?
I am on AT&T in USA,  Arizona...
I test the nightly builds.
But I have a build on one sd card I save, (August 26, I think) that I can use, that works for most functions.
August 31 appears to be ok,
it was a little laggy at first, and the first wake up was not promising,
but I just received my DHL shipper notification on the sms/text app, regarding my
PMOS Convergence phone.
 A few power cycles, phone calls, and texts,  now that release seems "OK"
NOTE:
It helps to have plenty of sd cards.
When you get a good working system, save that card .. !
Use different old or failed system cards to download the new 'to be tested' systems.
Then you can go back to a working system if you need it.
During the daytime I do use my Brave Heart phone,     " as a phone "
In the evenings I do my testing of new releases, and systems.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  atinout binaries for mobian/debian? NeutralGrey 2 115 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,818 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,145 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 170 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,131 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,905 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,181 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,966 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 662 07-05-2023, 03:57 AM
Last Post: paulcarton
