Announcing the Mobian project
#91
(07-01-2020, 04:21 PM)bcnaz Wrote: Text does "work"
But I am getting 3 copies of every incoming message ?    ( Just Me ?  )
 Just now flashed July 03 nightly build to my SD card,   plus I did an 'update'....
  I am now getting one copy of each incoming text
   > Flashlight icon is on the app screen and it works !   Nice
     the manual GUI  'update'  is working for me again.
but using the text app does occasionally cause the phone to reboot, but the reboot is now faster
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
#92
Update :
On a fresh boot, I cannot seem to open/originate my text App.
  I use my 'back-up phone' and send a fresh text to my Mobian phone that allows me to open the text App.  (?)
    Once it is opened, it re-opens as it should.
#93
I am curious about the accuracy of the reported battery voltage.
when it says : 100% charged 4.19 V ?
89% charged 3.95 V ?
This is a 5 V battery ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
#94
Lithium ion batteries typically have a maximum voltage of around 4.2V, and minimum around 3.0V. They're usually marked as a nominal 3.7V. Reported voltages look correct.
#95
Thank you, I did not know that.... ( Now I DO )
B.C.
#96
Is there a difference between getting a nightly build then updating that fully compared to the mobian-pinephone image from june 15, I assume there would be. how much does the mobian-pinephone image lag behind vs a nightly build?
#97
(07-07-2020, 09:30 PM)gizmuth Wrote: Is there a difference between getting a nightly build then updating that fully compared to the mobian-pinephone image from june 15, I assume there would be. how much does the mobian-pinephone image lag behind vs a nightly build?
Hi.
In my opinion, just use the command line and do an sudo apt update && apt distupgrade. Or use the software-center and look for updates. It worked for me. I got yesterday and today an operation system update. Try it out. Regards kowalskie.
Best regards
Andre (Lower Saxony, Germany)
#98
Hi All!
I couldn't find a good thread to post this question, so I decided to ask it here and then your are free to redirect me: my Hungarian Telenor SIM card does not seem to work with the Pinephone BH with Mobian. My Vodafone one works like a charm, Telenor suck ass, but I did not know that this hard.
According to the links below the modem should cover the bands the service is using, but still: nothing works.
https://www.frequencycheck.com/carriers/telenor-hungary
https://www.omgubuntu.co.uk/2019/11/pine...lease-date
Is there a way or where should I start digging to make this work?
Thank you in advance for your help!
#99
(07-09-2020, 01:43 AM)cefre00 Wrote: Hi All!
I use a Telenor Hello SIM in Hungary, it works for me. The APN for the mobile data is "online".
I hope, this helps.
Hi there,
I am impressed how well Mobian works on the Pinephone. However, notifications for Telegram are not working right now, is that correct?
  atinout binaries for mobian/debian? NeutralGrey 2 111 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,812 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,145 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 170 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,131 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,904 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,181 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,966 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 662 07-05-2023, 03:57 AM
Last Post: paulcarton
