pmos ( phosh really) 04/10
(04-15-2020, 05:44 AM)PureTryOut Wrote: We don't have a read-only partition, so "apk update && apk upgrade -a" (note that -a switch) will always get you the latest available. No need to reflash the image.
Quote:i split it up and ," apk update ", so i can see/ or list  what is being updated, then run "apk upgrade ".
Actually, you can just run "apk upgrade -i" (the -i switch) to see what is getting updated before you actually update.
Thanks, i will try it out for sure
(guess i had ubports on my mind)
  Fresh install pmos+phosh does not boot user641 1 509 10-08-2023, 04:04 AM
Last Post: user641
  [Not Pinephone] Phosh Autologin LienRag 11 2,132 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Boots To Shell After Dead Battery (PMOS) britelite 0 724 02-17-2023, 02:41 PM
Last Post: britelite
  No Application Data PMOS 21.12.1 Captain1ndustry 4 3,894 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 5,561 07-10-2022, 03:26 AM
Last Post: arkadione
  How to delete single sms in phosh? bircoph 1 1,384 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,699 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  closing apps rather than leaving them running (phosh) lordearl 7 6,234 02-03-2022, 09:14 PM
Last Post: parry
  Application list PMOS-Phosh jmorris 6 6,176 12-04-2021, 02:26 AM
Last Post: Juergen
  Phosh beta 10, no send button on Chatty? Rainer 0 1,635 05-24-2021, 08:17 AM
Last Post: Rainer
