How to boot Manjaro from NVME with uboot on eMMC
#31
(01-29-2020, 05:16 PM)mamboman777 Wrote:
(01-29-2020, 05:00 PM)tophneal Wrote: Yes. And yes it should. I didn't read that post as well as I should have, I think. I didn't notice the edit with the blank screen details either. Did you flash your uboot to the NVMe or SPI?
SUCCESS!!!!   Now I just need to get widevine going on Chromium.  That's my "netflix SD Card."  :-)
I honestly do not know/remember if my uboot is on the nvme or spi.  How could I check?
Thanks everyone!
Great! That's pretty easy with the script, luckily.
Hmm, I'm not entirely sure. Since you did it somewhat recently, you could go back to the install you used to do it and check your command history in the terminal or tty. You could also try removing/turning off your emmc, and then nvme. If it doesn't boot without the nvme, you know where it is. I think it's on your emmc, though. That's the second (and most common) place u-boot is looked for. You can test SPI (I think) by booting an SD with its u-boot zeroed out.
#32
I tend to be a pretty pragmatic guy when it comes to this kind of thing.... What reason would I have to check where uboot is? In the back of my mind, there's a voice saying "leave it alone! You just got it working!" Smile
#33
(01-29-2020, 05:59 PM)mamboman777 Wrote: I tend to be a pretty pragmatic guy when it comes to this kind of thing.... What reason would I have to check where uboot is? In the back of my mind, there's a voice saying "leave it alone! You just got it working!" Smile
Only for your own personal curiosity, friend! No worries, there's no pressure from me to do it. I'd advise you just assume it lives on your eMMC (because the SoC looks there first) and be mindful of that if you decide to format it.
#34
I think it is on the eMMC, too. There's another forum where I was advised to not flash spi,yet. If o decide to flash my emmc, for some reason, wouldn't that include the uboot?
#35
Thanks everyone!
Wait how did you fix it? Cause I have the problem you had.
#36
Thanks everyone!
I got the latest idbloader.img u-boot.img and trust.img from pcm720s git page (there is a link from the pinebook pro wiki page) and reflashed the boot on the emmc according to the instructions in the origional post.
#37
Thanks everyone!
weird, i just did that (went to pinebook page, grabbed the latest idbloader, u-boot, and trust.img files, dd'd (using these instruction on the git page
To flash it, use the following commands:
# dd if=idbloader.img of=<eMMC/microSD> bs=32k seek=1 conv=fsync
# dd if=u-boot.img of=<eMMC/microSD> bs=64k seek=128 conv=fsync
# dd if=trust.img of=<eMMC/microSD> bs=64k seek=192 conv=fsync
tried rebooting, it shut off, and won't turn on at all now. no green led or anything. tried different combination and nothing. totally bricked. wtf..
#38
You could try taking the eMMC out to see if you could boot from SD.
#39
Was able to fix it and recover my emmc. now its time to break some more stuff Wink
#40
Yay! Glad to hear it!
  Install Tow-Boot on the SPI Shad0w 13 8,694 04-19-2024, 12:20 PM
Last Post: alchemist
Question Can't Boot from MicroSD (What Am I Missing) falken 10 4,169 04-28-2023, 04:26 PM
Last Post: pinemouth
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,195 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,756 07-31-2021, 04:44 AM
Last Post: jiyong
  How to rewrite uboot to emmc pineitup 5 9,007 12-27-2020, 10:35 AM
Last Post: nightranger73
  How to install Ubuntu to eMMC and to install KDE (Neon) Wizzard 66 100,796 12-22-2020, 03:05 PM
Last Post: Wizzard
  Make your own Manjaro image flatulent_piney 0 3,291 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,230 10-24-2020, 06:38 AM
Last Post: pineitup
  Tutorial: Run Debian off NVMe hive 4 6,377 10-19-2020, 10:09 AM
Last Post: hive
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,478 10-02-2020, 12:20 PM
Last Post: wrzomar
