11-17-2019, 04:24 AM
Did someone managed to install archlinux on the Pinebook Pro?
Archlinux
11-17-2019, 04:36 AM
Manjaro is based on Arch and there's a thread about it - in my experience it works more or less, using a mainline kernel + panfrost GPU driver, but the USB-C currently only charges the battery and nothing else.
You should be able to reuse the kernel and u-boot from the latest manjaro preview, and put your own user space instead.
11-17-2019, 07:33 AM
@DrYak My question is: How does the wifi performance work on the Manjaro version?
I'm using the stock Debian wifi is unusable, weak and drops constantly. I've tried lots of troubleshooting, basically I may as well try installing Manjaro. I use Manjaro on all my other x86-64 machines, so makes a lot of sense. I'm sure there are bugs on all OS's though so might just be worth waiting.
11-17-2019, 11:01 AM
(11-17-2019, 07:33 AM)Eggmonkey Wrote: @DrYak My question is: How does the wifi performance work on the Manjaro version? Try `iwconfig wlan0 power off` to disable powersaving on the wifi adapter, that improved stability for me. You'll need to do that every time the machine comes out of suspend or boots (or write a systemd service to do it for you.)
11-17-2019, 12:13 PM
(11-17-2019, 11:01 AM)Arglebargle Wrote:(11-17-2019, 07:33 AM)Eggmonkey Wrote: @DrYak My question is: How does the wifi performance work on the Manjaro version? Thanks a lot for the suggestion @Arglebargle but no luck unfortunately - same issue - connects on boot, then either drops continually or the connection itself disappears from the taskbar after a few minutes. I've tried a lot of fixes but believe it is overheating and/or the driver needs improvement. I am about 2.5m from the AP for reference.
11-17-2019, 04:16 PM
To me it seems that 5Ghz is a bit more problematic than 2.4Ghz.
Since updating preview 2 of manjaro it seems a bit more stable. Still, the Broadcom wifi adapter crashed... ironically exactly at the moment where I was writing the unbind/re-bind trick to restart the driver (e.g. after using the privacy switch) could help reinitializing badly behaving chips.
11-24-2019, 05:51 AM
(11-17-2019, 04:36 AM)DrYak Wrote: Manjaro is based on Arch and there's a thread about it - in my experience it works more or less, using a mainline kernel + panfrost GPU driver, but the USB-C currently only charges the battery and nothing else. Thank you. I will try it with this kernel. |
Archlinux - missing firmware for wifi adapter | RudderDuck | 9 | 4,837 |
11-07-2022, 04:56 PM Last Post: wgahnagl |
ArchLinux on PBP | robieguarneros | 9 | 8,666 |
11-14-2020, 04:10 AM Last Post: robieguarneros |
