'Temporary failure in name resolution' Internet issue
I received my Pinebook today and I'm very impressed as it is a great machine.
One issue though: After usually around 2-3 minutes connected to the internet the internet drops on the device and I get 'temporary failure in name resolution' error when I try to ping a website. The net is clearly still up for the rest of my devices so I'm trying to get to the bottom of this issue so I can make pinebook usable. I'm sitting fairly close to the AP so I don't think it is like the 'weak wifi card' issue another user seems to be having
Any one have any ideas? Just thought I would ask before I troubleshoot through half a dozen possible fixes.
Maybe someone else has the same issue and we can learn something. If I fix it I'll write here.
OK, so resolv.conf had nothing in it, so I made it writeable with sudo chmod o+r /etc/resolv.conf, rebooted then it automaticlly added some hosts and the net has stayed up for 10 min so far
Actually, I think the wifi card is overheating and crashing. Internet drops after no more than 15min.
Wireless adapter disappears until a reboot.
var/log/syslog shows no panic, need to do more research but this issue looks like a theme after reading many other posts.
Any chance you had your CPU set to 1.99GHZ? I encountered a similar issue when I first got my Pinebook Pro and it stopped happening when I left the CPU set to Ondemand. Not sure if this is of any help, but I figured I'd speak up in the off-chance that this was a factor.
(11-11-2019, 11:40 PM)hikaricore Wrote: Any chance you had your CPU set to 1.99GHZ? I encountered a similar issue when I first got my Pinebook Pro and it stopped happening when I left the CPU set to Ondemand. Not sure if this is of any help, but I figured I'd speak up in the off-chance that this was a factor.
If you do something with the cpu, then also ondemand sets it to 1.99GHz.
I suspected that issue would be the case so I have tried it on low, medium and high CPU speeds but have the same problem. Takes 5-15 minutes for the net to drop out and takes a reboot to start working again.
Output from /var/log/syslog
.txt   varlogoutput.txt (Size: 51.91 KB / Downloads: 387)
This is why I thought DNS config issues.
  Issues with T-Mobile Home Internet? skinnyonthebebop 3 1,170 10-17-2023, 07:42 AM
Last Post: skinnyonthebebop
  Newbie with immediate issue jasonumd 1 1,025 03-04-2023, 05:59 PM
Last Post: hacknix
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,451 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 1,009 04-16-2022, 07:41 PM
Last Post: gehn5
Question USB-C Video Out Issue dev 2 1,915 02-08-2022, 07:28 PM
Last Post: dev
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,274 11-17-2021, 10:02 AM
Last Post: Phillip Bell
Bug [Fixed] Issue with mesa-git (Manjaro ARM Stable Update 2020-09-22)) JasonG-FR 20 22,199 12-12-2020, 05:09 AM
Last Post: mogwai
  Pinebook Pro PCIe init issue R32Fanboy 4 5,404 11-05-2020, 09:59 AM
Last Post: vssz
  Boot issue (red light) pineitup 10 10,323 11-01-2020, 11:26 PM
  Boot issue DarrowAtreides 0 1,743 10-29-2020, 07:23 AM
Last Post: DarrowAtreides
