The default OS / kernel had a wifi issue?
***  .My first wifi "DROP"  !!!
I have been on for about an hour -  but FireFox crashed for the first time also.. ?
Maybe one caused the other  or one thing caused both problems at the same time  ?
But the wifi reconnected automatically and I just restarted FireFox.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(11-14-2019, 03:57 PM)Eggmonkey Wrote: Anyone with fresh suggestions on how to fix this please let us all know.
I have not read much about the wifi issues. Perhaps that was discussed before?
I see wifi dying under high cpu load (which probably boils down to overheating).
Perhaps your laptop is always overheating for a reason TBD? What do your temp sensors read?
In idle it should be around 45C (at least on my machine)
$ cat /sys/class/thermal/thermal_zone?/temp
46250
45625
18800
When I stress the CPU with a parallel build, the temperature goes up to close to 70C and some time later, wifi shuts down.
I've been thinking about this, (though not experienced the issue my self).
How about checking the antenna connection?
 - Perhaps it's slightly loose, and heat causes it to get further loose. When the board cools down, the connector works better.
 - Or maybe a cold solder joint, (which works sort of). When things heat up it could get better worse depending on it's exact location.
Let us know what you find.
Arwen Evenstar
Princess of Rivendale
Issue was determined to be the wifi power management. The update that was just pushed, v1.5, will disable wifi power management after a reboot, which should resolve this issue Smile
(11-23-2019, 03:58 PM)Mrfixit2001 Wrote: Issue was determined to be the wifi power management. The update that was just pushed, v1.5, will disable wifi power management after a reboot, which should resolve this issue Smile
Thank you, troubleshooting section on the Wiki updated;
Wiki - Pinebook Pro - WiFi issues
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Commenting out  `iwconfig wlan0 power off` in `/etc/rc.local` solves the problem of wifi disconnects under load.
Running the default Debian,  executed `mrfixit_update.sh` a few hours before.
  Nethunter default password failed lamlarryyyy 0 436 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 1,058 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,865 09-07-2023, 09:38 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 873 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 1,060 08-18-2023, 01:58 AM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,304 07-15-2023, 02:58 PM
Last Post: u974615
  kernel module that supports usb-c hdmi alexandre 16 15,038 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 1,443 05-10-2023, 04:51 AM
Last Post: Vinay
  5GHz wifi not working snorwood 11 5,915 01-16-2023, 03:41 PM
Last Post: ehcorn
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,339 12-09-2022, 12:43 PM
Last Post: as365n4
