Utility to make Android SDCard image
I've downloaded the Android source and built it. I have all of the Android partition images.
So where is the utility that combines these partitions into a bootable SDCard image?
(02-13-2019, 12:29 PM)jonsmirl Wrote: I've downloaded the Android source and built it. I have all of the Android partition images.
Hello!
Did you manage to make a bootable SDCard? I'm looking to do the same with no success so far Smile
First you need to download the correct file, some are for eMMc boot and some are for the SD card.
Once you do that, i had the best luck with a tool called "balenaetcher" it will uncompress the file then flash it to the card.
The other programs i tried you need a zip program to first unzip the file before you flash it, i found this one to be the most simple and easiest but its just my opinion.
Ive had my board for about a week now and ive been trying about every version of Android so far i like the "Android TV 7.1 Community Build Image [microSD Boot] by ayufan" its way down at the bottom on the wiki.pine64.org download section.
Even though im not a fan of the leanback launcher style it runs the best on and SD card ive found
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,279 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,035 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,560 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,631 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,026 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,507 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,023 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,581 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,736 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,825 09-09-2020, 08:44 AM
Last Post: BowerR64
