Any way to use the wifi module?
i've bought the wifi module and didn't knew it was disabled in debian.
The bad thing is, that I can't connect my rockpro64 to a lan socket, so I have to use wifi somehow.
Now is the question, if there is some way to enable it again (because I don't really need PCIE support) or is that whole module bugged?
I would really appreciate your help, since I am a linux beginner.
Thanks,
Bluetexon
(11-28-2018, 01:23 AM)Bluetexon Wrote: Hello,
Thanks,
Bluetexon
It's enabled in 0.7.7
Thanks,
Bluetexon
Thank you for your reply, but I've read that already. I've tried that version yesterday but it didn't boot up.
Don't I also have some drawbacks using an older version?
There would definitely be a lot of drawbacks.
I suggest starting with [edit] v0.7.11 and then install kernel 4.4.138-1100
(I can't suggest anything with 4.4.154 yet because there's an i2s bug I haven't tracked down yet and I don't know which one it starts in, but I'll be finding that out soon.)
I'm personally using 4.4.138-1100 with a single tweak to the rockchip VOP driver source code to enable 4K framebuffer console.
Later today I'm going to attempt to re-arrange the device tree to re-enable sdio0 (which will allow our wifi modules to work) and disable pcie.
If I get that working, I'll post the edit.
  Installing Wifi drive for the RockPro64 John45595 0 332 02-10-2024, 11:32 PM
Last Post: John45595
  wifi interface on debian mruser1 2 2,360 10-14-2021, 09:07 AM
Last Post: mruser1
  External antenna for wifi tnmarktx 0 1,845 02-16-2021, 09:22 AM
Last Post: tnmarktx
  When did the wifi module start working? stormchaser3000 1 3,097 11-12-2020, 08:59 AM
Last Post: Darren
  RockPro64 - no WiFi/BT at this time? donblanco 2 4,193 04-27-2019, 04:24 PM
Last Post: RockPro64Newbie
  Wifi drivers pececitozipi 5 7,796 11-21-2018, 07:14 AM
Last Post: BackWoodsTech
  ROCKPRO64 Wifi Module Speed saisimha 2 5,573 05-24-2018, 01:50 PM
Last Post: saisimha
