PineA64+ Armbian not boot, black screen and log
After about one and half year of h24 running my Pine64 with debian armbian 3.10.107, I got a black screen with some message and last a "Call Trace" once. Then it require to insert root password. Then, "Press Ctrl+D to Continue". If I press Ctrl+D it reboots, and again from beginning.
I want to leave you the log captured on:
/var/log/syslog
using pastebin:
syslog
( It is not the entire log I've seen on my monitor. Is there a method to capture entire log in monitor during boot? )
Anyway, my question is: can I restore my Armbian SD without formatting?
(10-13-2018, 07:11 AM)klode Wrote: Anyway, my question is: can I restore my Armbian SD without formatting?
Do you have access to a card reader + PC running a recent flavour of linux?
If not can you live boot linux?
If you can you maybe able to fsck.ext4 the sdcard
I have found my issue. My fstab contains these rows:
UUID=14a75d65-c530-4d76-ba6d-ee50a8fafb15 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
/var/swap none swap sw 0 0
UUID=7EA0B9F2A0B9B14F    /media/leocric/PINESTORE               ntfs-3g  options=defaults,big_writes,nofail,streams_interface=xattr,acl,file_mode=0777,dir_mode=0777  0    0
/dev/sda2         /media/leocric/PStore4          ext4   defaults        0       2
//192.168.1.2/AurigaStore /media/leocric/STORA  cifs    user=leocric,pass=leo82cric80,iocharset=utf8,file_mode=0777,dir_mode=0777
/media/leocric/PINESTORE/ftp /var/www/klode/backups     none    defaults,bind   0       0
/media/leocric/PINESTORE/SERIES /var/www/klode/series   none    defaults,bind   0       0
/media/leocric/PINESTORE/Downloads      /home/leocric/Downloads         none    bind
I've got my error due to UUID=7EA0B9F2A0B9B14F, which was not connect to USB port. It was an external hard disk, with 2 partitions /dev/sda1 and /dev/sda2.
My question: how can I run anyway linux if one of fstab entry is not accessible?
(10-14-2018, 01:13 AM)klode Wrote: I have found my issue. My fstab contains these rows:
If you need to use fstab you can add noauto to the options, or if you are using a desktop, let it mount it automatically.
Question PINE64 PA642GB Armbian - no Microphone plug spel 1 3,646 11-09-2022, 01:46 PM
Last Post: pinebug
  Armbian 22.02 Release Announcement TRS-80 0 1,972 02-28-2022, 05:04 PM
Last Post: TRS-80
  Software Updates in Armbian CVBruce 1 4,024 07-10-2020, 09:07 AM
Last Post: martinayotte
  Using flashrom on PineA64(+) fearg 0 2,881 06-26-2020, 03:47 PM
Last Post: fearg
  Armbian for Pine64 xalius 22 55,725 05-07-2020, 06:27 PM
Last Post: bratoff
  How to enable mate/startx on boot in jessie desai_amogh 5 10,196 03-29-2019, 01:34 AM
Last Post: desai_amogh
  Armbian enable toucscreen right-click burningkrome 0 2,998 12-03-2018, 03:05 PM
Last Post: burningkrome
Exclamation Armbian Bionic on Pine A64+ black screen starmagoo 11 19,299 08-06-2018, 12:35 AM
Last Post: starmagoo
  +LTS/SOPINE kivy on armbian with lcd baumbachandrew 0 3,103 05-29-2018, 10:15 PM
Last Post: baumbachandrew
  Install VNC Armbian netpr 1 5,592 08-30-2017, 07:03 PM
Last Post: vinodmenon80
