Android Images (ROCK64)
Stock Build Android 7.1.2 [microSD Boot] [20170804] Release version
Stock Build Android 7.1.2 [eMMC Boot] [20170804] Release version
Stock Build Android 7.1.2 [microSD Boot] [20170809] Release version
Stock Build Android 7.1.2 [microSD to eMMC Boot] [20170809] Release version
Stock Build Android 7.1.2 [eMMC Boot] [20170809] Release version
Community Build Android TV 7.1 [0.3.4-86] Release version
Added Community Build Android TV 7.1 [microSD to eMMC Boot] [v0.3.4-r86] Release version
Added Stock Build Android 7.1.2 Rooted [microSD Boot] [20171012] Release version
Added Stock Build Android 7.1.2 Rooted [microSD to eMMC Boot] [20171012] Release version
Added Stock Build Android 7.1.2 Rooted [eMMC Boot] [20171012] Release version
nice!...?
I could not yet find a change log to read. I wonder if the root is the only change to the previous rom?...Desperately waiting to use my bluetooth dongle... greets Andfun
From the wiki:
- Rooted Android Build
- Updated to Rockchip SDK 170930
- Support USB update with update.img
I must say that for media the new release is super nice, mostly due to the pseudo-Leanback launcher that manages to combine the best of both worlds (ATV and regular Android). Nice.
well, Luke, i find the supplied launcher causes a lot more clicks than necessary. one click highlights, then 2nd click loads? why not just load on the 1st click? anyway, the launcher was the first thing i changed on the build. i wanted to say good job on the root this build. was able to update via supersu and the process did not bork the build. root checker shows that root install was proper and every app that needed root got it no problems. i will say that using terminal to give /system write privledges worked as needed. the only issue i have had is some of my paid apps do not register as paid on this build. i did update play services. . i just don't get why half work and half don't. anyway, good job on root this build, it's the best one since june 2016.
dkryder, I am using a regular remote with this build. Perhaps mouse/ keyboard behaves differently ?
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,270 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,030 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,557 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,022 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,503 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,018 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,577 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,728 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,808 09-09-2020, 08:44 AM
Last Post: BowerR64
  Boot Android from USB? Max_H 3 6,553 09-09-2020, 08:26 AM
Last Post: BowerR64
