Q4OS for PINEBOOK
#61
I am having trouble mounting a SD-card (256GB) with Q4OS on eMMC.
An error dialog pops up:
¨Unable to mount this device.
Potential reasons include:
Improper device and/or user privilege level
Corrupt data on storage device
Technical details:
org.freedesktop.DBus.Error.UnknownMethod: No such
interface 'org.freedesktop.UDisks2.Filesystem' on object at
path /org/freedesktop/UDisks2/block_devices/mmcblk1¨
#62
@Mayumi
Are you able to mount another mmc card ? Are you able to mount the device using terminal command "sudo mount /dev/mmcblk1p1 /mnt/work" ?
#63
(11-08-2017, 11:09 AM)q4osteam Wrote: @Mayumi
I used DD to remove all partitions of the SD card on my desktop (Linux Mint) and created one ext4 partition and formatted it. Now when I insert the SD card in my Pinebook it is mounted. A purple icon appears on the taskbar. I can create files, etc. I have no explanation why this didn't work before.
#64
Firefox 57 is now available in Q4OS, please see http://www.q4os.org/forum/viewtopic.php?id=1946
#65
Updated Q4OS (Pinebook) 2.4-r3 on Wiki and PINE64 Installer.
#66
(04-06-2018, 03:14 AM)pineadmin Wrote: Updated Q4OS (Pinebook) 2.4-r3 on Wiki and PINE64 Installer.
Anyone else tring this?-)
#67
Look at the Q4OS ARM/64bit full featured desktop with Debonaire theme in action, running on the Pinebook 14", tweeted - https://twitter.com/q4osteam/status/1021695252384624641
#68
Q4OS Scorpion for Pinebook has been updated from 2.4 -> 2.6, the most recent stable version. Please see Scorpion 2.6 announcement https://q4os.org/blog.html#news180908
Download: https://www.q4os.org/downloads1.html
Setup guide: https://q4os.org/dqa013.html
Initial credentials:
 Username: adminq
 Password: adminq
#69
Updated Q4OS (Pinebook) 2.6-r3 on Wiki and PINE64 Installer.
#70
Updated Q4OS (Pinebook) 2.4-r4 on Wiki and PINE64 Installer.
  DietPi OS for Pinebook MichaIng 3 5,520 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,625 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 957 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 745 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,843 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,276 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,935 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,307 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,853 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,826 12-25-2020, 04:40 PM
Last Post: ford442
