pinetab 2 not booting
Iv'e got my pine tab 2 to boot once again and the only thing it says is [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 it repeats this line 1 more time and below both lines I get a flashing cursor  does anybody out there know what it means? and what do I need to do to get it run again? please thisis driving me nuts pine64 insists that the community will help please!
No idea. Did you try asking the devs on Discord?
(07-13-2023, 05:09 PM)ajhiii070 Wrote: Iv'e got my pine tab 2 to boot once again and the only thing it says is [    0.000000] clk: failed to reparent gpll to clk_rtc32k_frac: -22 it repeats this line 1 more time and below both lines I get a flashing cursor  does anybody out there know what it means? and what do I need to do to get it run again? please thisis driving me nuts pine64 insists that the community will help please!
I have this error message as well plus some more but the PineTab2 is booting fine into the original Archlinux.
My guess is that your Linux is not starting and I think I remember that there were a few cases before and the advice was to reinstall the original factory image.
You find some instructions in the Wiki how to do that with the UART adapter that was part of the delivery (in the package with the power cable)
If you have more questions you can also join the chat, I recommend a matrix client (Element) because then you can search the chat.
(07-14-2023, 06:14 AM)Surehand53 It is gone again  there is no way to install a new image as it is not seen on any of my computers at this point it doesn't even turn on it is going back monday it hasn't worked correctly since it was delivered I'm over it and will move on to something else that will work as it's supposed to it wasn't ready for release and still isn't no wifi or bluetooth or cameras as I said I'm over it! Wrote:
Please translate in short simple sentences/Пожалуйста, переводите короткими простыми предложениями.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
For those who might find this.
To me the problem was that device battery was drained when plugged to power all worked again.
Chat GPT explained me that "the message "failed to reparent gpll" usually pertains to a warning related to the Graphics Phase-Locked Loop (GPLL) or another PLL on certain ARM chips during the boot process." Apparently this is just a warning but not the problem.
Check out discord for debug if problem still there (https://discord.gg/wmeb8687)
  PineTab Bluetooth PimpDiCaprio 0 65 05-29-2024, 11:11 AM
Last Post: PimpDiCaprio
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 8,520 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 641 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 3,195 09-01-2023, 01:13 PM
Last Post: acruhl
  Booting from SD card on Pinetab2 samochimaaron 10 3,352 08-23-2023, 09:38 AM
Last Post: diederik
  PineTab 2 Dead Screen Kramey 16 5,277 08-12-2023, 05:44 PM
Last Post: Kramey
  does the pinetab "just worK"? averageconsumer445 19 5,137 07-15-2023, 10:31 AM
Last Post: dachalife
  Pinetab-V shipping Status? jfstepha 6 2,648 07-12-2023, 03:23 PM
Last Post: ChromaticHamster
  Pinetab2 not booting. elix 10 3,274 07-09-2023, 02:42 PM
Last Post: elix
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,517 06-06-2023, 05:26 PM
Last Post: fxc
