Need to re-write U-boot from Pinephone pro currently in mass rom mode
Hi All;
I was trying to flash my emmc on Pinephone Pro and by mistake I erased instead my U-boot. I used an sd-card for the day and once the battery was drained the phone went into mass rom mode and I can no longer power it on.
After recharging the battery from a power station I tried to switch it on unsuccessfully. I tried as well the recovery mode (using the RE button on the back and it would work).
I can no longer see the device when running the lsblk command. However I see the rockship in mass rom mode when I run the lsusb command from my linux labtop.
I read few instruction and a script provided by the rkdeveloptool-master to flash the memory and see if I can copy across a new bin file (rk3399_loader_spinor_v1.15.114.bin) and from there being able to move out of the mass rom mode and use again the sd card. It was not successful.
I was wondering if there is U-boot image available that I can use and how can I copy it across to my phone memory since I am still on mass rom mode. I guess there are 2 questions in 1:
a) how to move out of the mass rom mode
b) How to reinstall the Uboot in my Pinephone Pro
Thank you.
You are in wrong forum section,,
this is pineBOOKpro,, go down (in forum) to pine PHONE section
  uboot wont boot to SD card after upgrade jbradley419 7 815 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 288 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,223 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 687 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 585 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,174 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,867 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 799 07-13-2023, 01:50 PM
Last Post: PaulQ
  Pinebook Pro (+ Pinephone) for sale (UK, London) chaoskampf 8 3,938 07-10-2023, 10:29 AM
  New Pinebook pro won’t boot Generaltuxenburg 4 1,936 06-14-2023, 07:20 AM
