Cannot Boot From SD Card
I recently got a PineBook Pro and wanted to try a different OS.  I downloaded and flashed Armbian and TwisterOS images to micro SD cards, but I cannot boot from them.  When I power on the PB with the micro SD card inserted, the screen is blank and the power light blinks about once per second.  Is there something else I need to do to?  I feel like there's something obvious I am missing.
This should be a "sticky" somewhere.
The version of Manjaru that comes pre-installed on the 2022 Pinebooks Pro, includes a U-boot that does not allow booting from micro-SD card.
The ways to resolve this are
1) replace the U-boot on the eMMC with a different one, or possibly Tow-boot
2) wipe out the eMMC and install a different operating system on it.
3) install Tow-boot to SPI ROM (I do not actually recommend this, but it can be done, apparently).
4) disable the eMMC
:wq
[ SRA accepts you ]
(10-28-2022, 06:27 PM)KC9UDX Wrote: This should be a "sticky" somewhere.
4) disable the eMMC
Thanks for the reply!  I was able to install Tow-boot to the SPI Flash by following their directions and that gives me a boot menu.  However, I had to disable the eMMC first.
This was helpful!
4) disable the eMMC
Where are the HOWTOs for options 1-3?
(11-12-2022, 01:06 AM)jazzhands Wrote: This was helpful!
Thanks.
Hopefully you can find everything here: https://forum.pine64.org/forumdisplay.php?fid=117
That is where all the Pinebook Pro tutorials are supposed to be.  Except for using Tow-boot, I have been doing these things the hard way since the early days of the PBP, and I just muddle my way through every time.
:wq
[ SRA accepts you ]
  uboot wont boot to SD card after upgrade jbradley419 7 912 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 307 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,297 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 723 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 612 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,231 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,940 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 817 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,985 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,475 05-20-2023, 01:02 AM
Last Post: jackwilson
