Booting Arch from USB
Hi
I've just installed Linux Arch (for PineBook Pro) on a USB stick following the official guide https://wiki.pine64.org/wiki/Installing_...nebook_Pro
everything went well. However, when I tried to reboot the new installation from USB, it just went to the default Manjaro installation. That happens if I plug the USB stick on the left. I tried to plug it on the right port, and it works: I can boot it! So is it true that I cannot boot from the left port (the port works since I installed Linux Arch on the USB stick using that port)? I seem to understand that the left port is USB 3, while the right port is USB 2? Or am I wrong?
I went ahead and tested, following the instructions you linked, and I'm successfully booting from the USB 3 port on the left-hand side into Arch. Did you flash Tow-Boot to the SPI or just to the SD card? That's the only reason I can think that yours wouldn't work short of a defective USB port.
(09-10-2022, 03:40 PM)steeb Wrote: I went ahead and tested, following the instructions you linked, and I'm successfully booting from the USB 3 port on the left-hand side into Arch. Did you flash Tow-Boot to the SPI or just to the SD card? That's the only reason I can think that yours wouldn't work short of a defective USB port.
Hi
I followed https://wiki.pine64.org/wiki/Installing_...nebook_Pro using /dev/sda instead of /dev/sdb because my USB stick was /dev/sda. I did the procedure with the USB stick inserted on the left-hand side, so that port works. The tutorial instructs you to flash tow-boot directly to the USB stick and that's what I've done.  If I try to boot with the USB stick on the left-hand port it boots to the standard Manjaro, so it does not consider it. If I plug the USB stick on the right-hand side, the U-boot on my PineBook Pro detects the installation on the USB stick and correctly boots it.
I received a notification via email of a previous answer of yours, which, however, I cannot see in the forum. In the email I can only read this part
The default U-Boot doesn't support booting from USB, if you haven't yet flashed the SPI, you should ... (visit the thread to read more...)
I deleted my original comment since I hadn't fully read your initial post (my bad!) But yeah, the only difference between your setup and mine is that I flashed Tow-Boot to the SPI instead of the flash drive and it boots fine from both USB ports.
(09-11-2022, 01:06 PM)steeb Wrote: I deleted my original comment since I hadn't fully read your initial post (my bad!) But yeah, the only difference between your setup and mine is that I flashed Tow-Boot to the SPI instead of the flash drive and it boots fine from both USB ports.
Ok, thanks for the update.
But what happens if I flash tow-boot to the SPI? Will I still be able to boot the original Manjaro installation? Moreover, where do I find the commands for flashing tow-boot to the SPI?
Many thanks in advance.
Apparently, something has changed: I can now boot also from the left port... I don't know why... maybe it was just a matter I had to remove the USB stick after the installation before trying to boot?
(09-12-2022, 10:33 AM)lorebett Wrote: Apparently, something has changed: I can now boot also from the left port... I don't know why... maybe it was just a matter I had to remove the USB stick after the installation before trying to boot?
Looks like I can boot from the left port the first time, after some time the computer was off. But if I reboot, it doesn't work anymore... only on the right-side
  By the way, yay arch... KC9UDX 4 721 03-30-2024, 10:27 PM
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 971 08-18-2023, 01:58 AM
Last Post: juliamenendez
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,841 04-01-2023, 02:58 PM
Last Post: TRS-80
  PineBook HOW TO REINSTALL ARCH-Manjaro. Ice-O-Star 0 914 10-22-2022, 10:46 AM
Last Post: Ice-O-Star
  Arch Linux ARM root filesystem SKiljan 24 20,825 09-24-2022, 03:11 AM
Last Post: alexandre
  pinebook pro not booting cricket 1 1,185 08-17-2022, 04:38 PM
Last Post: cricket
  Manjaro and Arch repository with privacy oriented software as400 86 113,637 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  PBP not booting anymore jsch 5 2,911 04-21-2022, 11:24 AM
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,083 03-22-2022, 06:37 PM
Last Post: pentamassiv
  Help with bypassing Arch check in Pamac JoshTheTofu 2 2,145 11-26-2021, 07:32 AM
Last Post: user18130814200115
