pinephone-support package not upgradable on Mobian
Hi everyone,
I've been casually using my PinePhone Mobian community edition for the past year and a half or so and love the progress that's being made on mobile Linux.
Yesterday I've installed some updates but I've noticed a package got held back, specifically the pinephone-support package.
Trying to apt install this single package gives me a warning that it can't be installed because "the following packages have unmet dependencies: pinephone-support: Depends: firmware-realtek-rtl8723cs-bt but it is not installable, unable to correct problems, you have held broken packages.".
I never ran into this before (plus the updates also uninstalled my gnome-software store + gnome-software-flatpak-plugin and settings application) and am kind of at a loss how to solve it since the package can't be found or upgraded. It seems kind of essential?
Did anyone else run into a comparable situation?
Thanks in advance!
yes I have ran into this problem, not sure if mobian support has gone belly up, last weekly build is 2022-08-21. I have been surviving with apt update, apt upgrade, apt dist-upgrade. There always seems to be some packages left behind, don't do apt auto-remove those packages are important. Had to go back to a weekly build to get the packages back.
(09-18-2022, 05:42 PM)AnAbolitionist Wrote: There always seems to be some packages left behind, don't do apt auto-remove those packages are important.
Just a question: What packages do you mean exactly? Huh
I do auto-remove regulary since I use Mobian, and it never caused problems (I did it NOT during the dependency problems which removed settings-app of course, but when my Mobian was "OK" before auto-remove -> It was also "OK" afterwards).
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
My concern was as you stated, when it doesn't upgrade cleanly, don't auto-remove it wipes out useful applications off the desktop.
(09-23-2022, 07:09 PM)AnAbolitionist Wrote: My concern was as you stated, when it doesn't upgrade cleanly, don't auto-remove it wipes out useful applications off the desktop.
OK, then I just misundestood. Cool
Thanks for clarification!
  Pinephone boot. Richy_T 4 101 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 854 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 431 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 290 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,876 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,928 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 667 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,520 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 545 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,792 12-22-2023, 03:44 PM
