no audio ring on non chatty calls
fresh install on danctnix's phosh Arch image everything works as normal except none chatty notifications.
I have extended the feedbackd config to sound on missed as well as new sms and IM these work as inconsistently.
if the screen is locked and no existing (dino-im in this case) notifications have sounded then the sms sound plays (the screen doesn't turn on)
if I am in different app screen on no sound is played notification is displayed.
if a voice/video call comes through on the app no sound is played regardless of state, visual notification is displayed.
have tested incoming call event with fbcli and chatty both work (chatty also turns on screen).
below is a capture of the dbus event it appears to invoke incoming-call sound but no audio ring is played the screen doesn't turn on.
any ideas where I should look next ?
signal time=1660509632.125137 sender=org.freedesktop.DBus -> destination=:1.90 serial=2 path=/org/freedesktop/DBus;
  string "Dino"
  uint32 0
  string ""
  string "SENDERADDRESS"
  string "Incoming call"
  array [
      string "default"
      string "Open conversation"
      string "reject"
      string "Reject"
      string "accept"
      string "Accept"
  array [
      dict entry(
        string "sound-name"
        variant            string "phone-incoming-call"
      dict entry(
        string "urgency"
        variant            byte 2
      dict entry(
        string "image-path"
        variant            string "call-start-symbolic"
      dict entry(
        string "desktop-entry"
        variant            string "im.dino.Dino"
  int32 0
  Phone calls with no sound user641 14 6,700 03-12-2023, 11:43 AM
Last Post: alpineduck
  Still No Calls or SMS AndyM 3 1,829 03-10-2023, 05:27 AM
Last Post: AndyM
  No audio on calls after using wired headset Zebulon Walton 2 1,489 12-07-2022, 07:35 PM
  Chatty not receiving encrypted xmpp messages on suspend mode user641 0 775 11-17-2022, 05:16 AM
Last Post: user641
  Chatty and OMEMO user641 1 1,204 09-27-2022, 12:47 PM
Last Post: user641
  Incoming calls only vibrate, phone is not ringing lacriz 4 3,530 05-31-2022, 11:40 PM
Last Post: hannescam
  2022 01 28 Updates Break Chatty mikehenson 5 3,385 02-12-2022, 09:31 PM
Last Post: Danct12
  audio services shut down after short time on arch-phosh pineuser0 3 2,659 01-22-2022, 01:14 PM
Last Post: elagost
  2 weeks after installation during calls people hear me but i don`t hear anyone 7horns7eyes 10 7,179 01-22-2022, 08:16 AM
Last Post: kmsgli
  Howto enable MMS support in Chatty on Phosh? (PinePhone) ramona.fulton 2 2,851 11-18-2021, 02:58 PM
Last Post: Danct12
