Chatty and OMEMO
Hello, I am strugling to use jabber on my pp, for my use chatty would be enough, but omemo is not working yet, is there a way to fix it or it depends on software updates?
Another solution would be dino, to use dino, should I just install the standard version on arch repos or it needs some package to make it mobile friendly? How's about gajim, anyone using it, is it mobile friendly?
(09-22-2022, 01:15 AM)user641 Wrote: Hello, I am strugling to use jabber on my pp, for my use chatty would be enough, but omemo is not working yet, is there a way to fix it or it depends on software updates?
I installed libomemo and libpurple-lurch, now I can activate OMEMO on every chat, but after sending a message with OMEMO I  the following error: the device XXXXX onwned by myuser@mydomain does not have a bundle and will be skipped. The owner should fix this, or remove the device from the list.
How to fix it?
Just found this similar problem: https://github.com/gkdr/lurch/issues/106
  Chatty not receiving encrypted xmpp messages on suspend mode user641 0 761 11-17-2022, 05:16 AM
Last Post: user641
  no audio ring on non chatty calls nemsys 0 794 08-14-2022, 03:23 PM
Last Post: nemsys
  2022 01 28 Updates Break Chatty mikehenson 5 3,354 02-12-2022, 09:31 PM
Last Post: Danct12
  Howto enable MMS support in Chatty on Phosh? (PinePhone) ramona.fulton 2 2,833 11-18-2021, 02:58 PM
Last Post: Danct12
  2021 Jun 23 Updates breaks chatty [solved] mikehenson 2 2,653 06-27-2021, 04:41 AM
Last Post: AndyM
