Pinephone pro doesn't boot up anymore
Sad
Good morning,
I tried to install mobian on emmc but I hadn't changed the bootloader, from that moment the phone doesn't turn on anymore.
I tried with sd card inserted, without sd card and holding down the RE button.
I tried to connect the phone to the PC but not with the lsusb command it never appears.
Is there any way to fix the phone? spare parts?
The Pinephone Pro is a beautiful project that I would like to learn more about.
Thanks for your attention,
Giacomo
You can follow the procedures here. Or else a Mobian installation can be complemented or saved by installing Tow-boot.
https://wiki.pine64.org/wiki/PinePhone_P..._corrupted
(08-09-2022, 04:22 PM)mburns Wrote: You can follow the procedures here. Or else a Mobian installation can be complemented or saved by installing Tow-boot.
Thanks for the reply,
I tried to rewrite a microsd with a fresh mobian image but the phone never showed any signs of life.
Anyway thanks to the attempts made on your advice, I now see this command line output:
Bus 003 Device 010: ID 2207: 330c Fuzhou Rockchip Electronics Company RK3399 in Mask ROM mode
I've done some research but don't know how to continue from here.
any suggestions?
  PinePhone Pro EDL boot by shorting contacts ozkenlc 1 155 05-01-2024, 09:29 AM
Last Post: traut
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 824 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 435 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,272 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 247 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,888 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,225 11-18-2023, 07:25 AM
Last Post: crocspot
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 2,743 08-13-2023, 04:50 AM
Last Post: fxc
  Pinephone pro packet injection for internal wifi chipset covar 1 846 08-13-2023, 04:40 AM
Last Post: fxc
  PPP not booting/starting anymore JonnJonz 1 614 08-09-2023, 01:53 AM
Last Post: alaraajavamma
