Curious About Arch
Hey all,
Lately I've been curious abour Arch on the pinephone, and have some questions about it!
1) how stable is it? Is it could for daily drivin?
2) What are some of the current issues that users are facin with it?
3) What apps can you install on it? Can you use Chatty?
4) Can you use Lomiri with it? I've always liked that de, but don't really like ubuntu touch itself
5) Is Arch easy to install?
Thanks!
Edit: Typo
Hi! I haven't used Arch for a while, but i can respond to some of the questions
1) Fairly stable, but sometimes things will break. Phosh image is most stable
2) It's more on the edge compared to mobian so you'll most likely get updates earlier. that's good and bad. Danct12 is the sole maintainer so the project is dependent on his continued interest in the project.
3) Yes, if you install the phosh version chatty is installed by default
4) short answer: no. You can probably get a buggy mess to work, but it's not usable. Lomiri developers wants to support other distroes in the far future.
5) yes, you can find images here: https://github.com/dreemurrs-embedded/Pi...g/20220502
Run sudo pacman -Syu in the terminal on the first run so it gets properly upgraded before you start using it. (password 123456)
Join the  active community on:
[*]Matrix: #archmobile:kde.org
[*]Telegram: @archlinux_pinephone
(07-24-2022, 04:40 AM)Nooblife Wrote: Hi! I haven't used Arch for a while, but i can respond to some of the questions
hey there! thanks for answerin those questions for me! meant to come back to the forums sooner... life got very busy lol. I'm really considerin switchin to Arch, and this helps a lot!!
  Updating Arch Linux _radv_ 8 842 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,266 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 794 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,954 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,877 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 915 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 854 12-03-2022, 08:35 PM
Last Post: Chief
  Latest version Arch Plasma looks good. Chief 5 2,468 10-23-2022, 01:53 PM
Last Post: Chief
  Evolution no longer runs on Arch Phosh. Chief 2 1,418 10-17-2022, 07:22 AM
Last Post: Chief
  Reticulum's Nomadnet (mesh net) on Arch ARM PineFone 0 840 10-16-2022, 08:28 AM
Last Post: PineFone
