ArmbianTV 20230918 kernel current 6.4.16 and edge 6.5.4
new u-boot 2023.10-rc4
Armbian and LibreELEC and AltLinux for Quartz64
Hello! I am interested in building a Quartz64A 8GB based headless NAS (Pine64 NAS case, eMMC module, PCI-e SATA card, 2x HDDs, power supply). I currently have a RockPro64 4GB based NAS in an identical setup which ran perfect for years. Now I'd like an extra NAS.
Is there an image available for the Quartz64 that supports/enables all hardware for such a setup? Do I understand correctly that the official Armbian images (found here) do not work? @balbes150 I see you posting version updates to several OS images. Where can these be found/downloaded? Is a 'normal' Armbian image available? Either way, thanks for all the hard work you seem to be doing Cheers! Thomas
PinePhone (BH 2GB + CE 3GB) // RockPro64 4GB (rev. 2.1) - OMV NAS // PineH64 3GB (model B) - off-prem OMV NAS // Pine64-LTS 2GB (rev. 1.2 + Playbox) - Domotics server
10-02-2023, 08:38 AM
(10-02-2023, 12:06 AM)p1x3l3d Wrote: Hello! I am interested in building a Quartz64A 8GB based headless NAS (Pine64 NAS case, eMMC module, PCI-e SATA card, 2x HDDs, power supply). I currently have a RockPro64 4GB based NAS in an identical setup which ran perfect for years. Now I'd like an extra NAS. Maximum hardware support in CURRENT. Although the EDGE version can also work for a headless server. You can test both versions and check which ones better support your specific PCIe hardware. I don't check the official images at the specified link and don't know if they work or not. See the first post of this topic, there are all links to images by models.
10-06-2023, 06:01 AM
Libreelec kernel 6.4.16
Armbian kernel current 6.5.5 and edge 6.6-rc4 Altlinux kernel 6.5.5
10-10-2023, 07:27 AM
Libreelec kernel 6.5.5
11-02-2023, 07:50 AM
Armbian kernel current 6.5.9 and edge 6.6.0
11-13-2023, 07:45 AM
Libreelec kernel 6.6.1
Armbian kernel edge 6.6.1
Armbian kernel current 6.5.11 and edge 6.7-rc1
05-02-2024, 09:09 AM
Armbian kernel current 6.6.28 and edge 6.9-rc5
irradium (based on crux linux) Quartz64 riscv64, aarch64 | mara | 0 | 237 |
03-27-2024, 12:53 PM Last Post: mara |
DietPi OS for Quartz64 | MichaIng | 45 | 11,221 |
12-12-2023, 02:26 AM Last Post: sickos |
slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) | mara | 56 | 41,713 |
10-17-2023, 10:55 AM Last Post: mara |
quartz64-a - on-board SATA port problems | manning | 2 | 1,183 |
09-14-2023, 04:22 PM Last Post: manning |
How the reset Quartz64-b onboard memory (emmc) | beepy | 2 | 873 |
07-20-2023, 10:44 PM Last Post: beepy |
Armbian RAM issue | JambonLeVrai | 2 | 1,386 |
02-12-2023, 06:48 AM Last Post: diederik |
crux-arm Quartz64 RK3566 (aarch64) | mara | 5 | 5,068 |
10-29-2022, 06:55 AM Last Post: mara |
Ov5647 camera attached via csi to Quartz64 /Soquartz | Randomuser | 0 | 1,268 |
07-21-2022, 01:08 PM Last Post: Randomuser |
Armbian on Quartz64 | dieselnutjob | 34 | 27,022 |
03-17-2022, 06:29 AM Last Post: balbes150 |
