Pinephone Pro impossible to switch on
hello everybody,
i received my PinePhone pro a few day ago. I was very happy. Everything worked fine until impossible to switch on.
Impossible to connect from my laptop (not present with lsusb), no message on phone's screen (nothing). I try to boot on SD card, no way....
Could you please help me?
Regards,
Hi @gerard
Have you got your phone started yet ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(01-29-2022, 07:13 AM)gerard Wrote: hello everybody,
Regards,
I also can't connect to a laptop.  Still using the Manjaro install that comes with the phone.  I can see the device with lsusb after connecting the USB A/C while pressing the RE button on the back, but I can never get the connected message/image on the phone or in any way access the eMMC or microSD (other than from the phone itself).  I've connected the USB A/C while PPP is powered off, powered on, pressing RE, using a USB2 port, a USB3 port, with the microSD inserted / not inserted, on a train, on a plane, while wearing sox, and with a fox.
I also flashed postmarketOS to the microSD and inserted it.  I've tried every way I can find described to boot from the microSD including these instructions from the wiki, https://wiki.pine64.org/wiki/PinePhone_Pro:
The Explorer Edition comes with a modified U-Boot pointing to the microSD card pre-installed to the eMMC. The microSD card can be (temporarily) booted instead of the pre-installed operating system, when the power key is shortly held at boot. To always boot from the microSD card it is recommended to wipe U-Boot from the eMMC. When the pre-installed bootloader was overwritten with a bootloader without such a configuration, the RE button underneath the back cover of the phone can also be used to temporarily bypass the eMMC. The button may however only be pressed shortly for a few seconds during boot, otherwise the eMMC won't be initialized in the operating system.
Lastly, I read somewhere about booting while pressing power/volume up simultaneously.  That doesn't work either.
Any thoughts?
  PinePhone - boot from microSD laserpyramid 7 604 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 364 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 244 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,505 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,841 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 618 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,383 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 508 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,716 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,991 12-04-2023, 02:14 AM
Last Post: Peter Gamma
