Mobian and Deep Sleep Crust
I'm using Debian bookworm on Pinephone, installed on eMMC now. And seems to drain the battery pretty fast (faster then Manjaro ARM on the same device). How can I monitor the use of CRUST deep sleep? IS it enabled now?
Is there the difference between kernels 5.15 and 5.10 regarding power save?
(11-13-2021, 04:10 AM)some_pinephone_user Wrote: I'm using Debian bookworm on Pinephone, installed on eMMC now. And seems to drain the battery pretty fast (faster then Manjaro ARM on the same device). How can I monitor the use of CRUST deep sleep? IS it enabled now?
I've just looked into a dmesg of modem firmware, and there is nothing about deep sleep, but in the kernel of mobian there is deep sleeps. This indicates, that the modem doesn't getting into deep sleep on Mobian.
As figured out, the kernel of modem never goes to deep sleep. So the question is solved.
  atinout binaries for mobian/debian? NeutralGrey 2 107 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,798 05-09-2024, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,144 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 170 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,130 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,904 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,180 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,966 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 662 07-05-2023, 03:57 AM
Last Post: paulcarton
