06-22-2016, 06:17 PM
The camera module is working on Linux 3.10.102.
Have a look here: http://forum.armbian.com/index.php/topic...or-pine64/
Camera is working on Linux
06-22-2016, 06:44 PM
kewl including guvcview into the next debian image release (Mate and XFCE)
If you like my work be sure to check out my site or wish to donate to the cause
Cheers
PKernel 3.10.102 longsleep, get
My modified guvcview github.com/avafinger
06-22-2016, 10:47 PM
@lex, this?
https://github.com/avafinger/guvcview updated to include pine64 yet? btw, thanks. now i just need a camera.
06-22-2016, 11:38 PM
nice... now i just need my camera to get here...
06-23-2016, 10:44 AM
(06-22-2016, 10:47 PM)dkryder Wrote: @lex, this? Yes, updated to compile on pine64+. BTW, if someone has hm5065 module should update to 3.10.102 and compile DTB and give it a try, maybe this can work (only if the module works on Android).
06-23-2016, 11:01 AM
Nice! I should order a camera module, but I still got two USB cams sitting around...
Come have a chat in the Pine IRC channel >>
On (up to date) Ubuntu I get:
Code: $ guvcview Code: $ uname -a There is no /dev/video* and no /dev/v4l* How do I fix this or go about finding the cause?
06-28-2016, 04:58 PM
STEP 1
sudo -i resize_rootfs.sh reboot STEP 2 (After Reboot) sudo -i pine64_update_uboot.sh pine64_update_kernel.sh reboot STEP 3 sudo -i apt-get -f install apt-get install v4l-utils
Cheers
06-28-2016, 11:31 PM
That doesn't help for me. I'm running Debian, uboot and kernel are updated to newest. It seems that system just doesn't see the camera at all. There's no /dev/video and dmesg shows v4l-modules loaded with "device as (null)". Full dmesg here.
There have been different information about the required kernel module. Some say it's hm5065, others ov6650 or s5k4ec. I've tried them all and several others with modprobe with no luck. At the moment my lsmod says Code: root@pine:~# lsmod Could someone with the soc camera working post their lsmod? Or dmesg? I have no idea where to continue now. |
Anyone get the camera to work yet? | Havensal | 16 | 26,589 |
09-13-2022, 03:31 AM Last Post: harryaxe31 |
camera port details? | gourmand007 | 6 | 14,864 |
03-07-2021, 05:29 PM Last Post: DippingMyToesIn |
About the camera | robopo | 11 | 21,492 |
03-06-2021, 12:28 AM Last Post: DippingMyToesIn |
CSI / Camera Module Compatibility? | vade | 8 | 16,908 |
04-03-2020, 05:39 AM Last Post: Ellesar Dragon |
13MP Camera cable extension | saviod | 2 | 5,220 |
06-21-2019, 06:05 AM Last Post: saviod |
Camera | Sasank | 15 | 26,704 |
12-13-2018, 09:08 PM Last Post: Mutani |
Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel | themyshop | 3 | 7,153 |
05-10-2018, 04:28 PM Last Post: tllim |
Webcam vs camera module on pine64+ | fkpkot | 4 | 10,051 |
02-27-2017, 03:57 PM Last Post: MarkHaysHarris777 |
camera module and lcd integration | jodybrown99 | 5 | 9,050 |
10-11-2016, 11:35 AM Last Post: hikaricore |
