About the camera
Some questions about the Pine camera:
- What is the status of the camera module, when will it be available?
- Is the camera connector perhaps the same as in Raspberry Pi 2 and if so can Raspberry Pis camera be used with Pine while waiting for the pine camera?
- can the camera video be synced with external pulse? This would make the pine camera extremely useful and the lack of this is perhaps the major deficiency in the RPi camera system.
rap
(01-11-2016, 11:12 AM)robopo Wrote: Some questions about the Pine camera:
rap
- The camera info loacted at http://wiki.pine64.org, the camera will be available immediately after Kickstarter campaign.
- The camera connector is different than RPi, the RPi camera cannot be use in Pine A64. RPi camare using serial bus type and Pine A64 using parallel bus type.
- I don't know much about synced with external pulse, if you have website that can reference to, I will check and get you an answer.
Any camera manufacture you may use will know about video synchronization to external master pulse.
For instance, for 3D video capture (stereo etc.) all the multiple cameras must take the video frames exactly at the same time. They do this by following an external electrical master pulse. Most industrial cameras are capable of doing this.
rap
PS: Image Acquisition: Handbook of machine vision engineering:
https://books.google.fi/books?id=UmzsCAA...se&f=false
(01-11-2016, 01:39 PM)robopo Wrote: Any camera manufacture you may use will know about video synchronization to external master pulse.
rap
The camera module itself don't have the master pulse control, you may able to use GPIO pin to receive master pulse input if you interest in DIY.
Yes, but will the camera be able to act upon the the GPIO input (interrupt) signal? For instance Arducam has made a camera with FREX and STROBE signals for but Raspberry Pi firmware can not utilize these signals. You will win all the camera enthustiatics on your side if you make this possible. Please ask you camera manufacturer about this. Some talk on the RPi forum about this:
https://www.raspberrypi.org/forums/viewt...8&start=50
rap
(01-11-2016, 01:55 PM)robopo Wrote: Yes, but will the camera be able to act upon the the GPIO input (interrupt) signal? For instance Arducam has made a camera with FREX and STROBE signals for  but Raspberry Pi firmware can not utilize these signals. You will win all the camera enthustiatics on your side if you make this possible. Please ask you camera manufacturer about this. Some talk on the RPi forum about this:
rap
Such a same world, Arducam folks and us already communicate with us and they will look into such possibility :-)
After you have been talking with your camera manufacturer(s), is there now new any information about the camera and about the video synchronization to external master pulse issue?
rap
Hi guys,
I'm interested in using the camera module as weel. I'm gonna buy a Pine64 soon, can you point me to a good camera I can use?
I really need a sync signal too, though I could get by with an output instead of an input. I just need to flash a strobe while the "shutter" is open, so any signal that precedes the exposure consistently would do for me. Anybody know a chip that can do it?
Sent from my iPhone using Tapatalk
(03-25-2016, 12:36 AM)davegadgeteer Wrote: I really need a sync signal too, though I could get by with an output instead of an input. I just need to flash a strobe while the "shutter" is open, so any signal that precedes the exposure consistently would do for me. Anybody know a chip that can do it?
You are second person ask about this question, I will check and response back.
  Anyone get the camera to work yet? Havensal 16 41,288 09-13-2022, 03:31 AM
Last Post: harryaxe31
  camera port details? gourmand007 6 21,797 03-07-2021, 05:29 PM
Last Post: DippingMyToesIn
  CSI / Camera Module Compatibility? vade 8 25,636 04-03-2020, 05:39 AM
Last Post: Ellesar Dragon
  13MP Camera cable extension saviod 2 8,883 06-21-2019, 06:05 AM
Last Post: saviod
  Camera Sasank 15 40,151 12-13-2018, 09:08 PM
Last Post: Mutani
  Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel themyshop 3 11,524 05-10-2018, 04:28 PM
  Webcam vs camera module on pine64+ fkpkot 4 15,390 02-27-2017, 03:57 PM
Last Post: MarkHaysHarris777
  Camera is working on Linux @lex 50 138,564 10-26-2016, 03:17 PM
Last Post: @lex
  camera module and lcd integration jodybrown99 5 15,290 10-11-2016, 11:35 AM
Last Post: hikaricore
