Product Idea : PineProbe
I would love to see a mini usb scope that I could use on my pinephone !
Preferably a small probe (pen like), something like picoscope 2105 (discontinued) or bitscope 05
Problem with the latter two is that software is not opensource, they offer binaries for arm based distributions, but only in 32bits and so they won't work on pinephone
About the capabilities ?
 - It should be able to analyze CAN/I2C/SPI so 2MHz bw at least (might be on the edge for 500k CAN) ...
 - 1 analog and 2/4 logic ways per probe and the ability to plug a second probe to the first one to sync channels
 - usb-c
There was a video of someone using a softscope on the pinephone, I've not found it again. Do someone have a link ?
Found a bitscope bs05 at work and could try it on the pinephone.
Guys at bitscope told me that arm64 package might be ready in may (they still have problems with graphics)
I've been able to try the armhf package by adding the architecture (via dpkg --add-architecture) on my first pinephone (won't use my main one for that Wink
The app runs and the scope is correctly powered by the phone.
The logic analyser works ok, but I had some display trouble with the digital osciloscope (dso) application, it doesn't show me the trace, which is anoying for a scope Wink (tried also using xorg but it is not a xwayland problem) hope the work on arm64 version corrects that ...
It seems a good way to have a portable scope in your pocket.
taken this photo from my main pp (don't mind the mess)
(03-18-2021, 04:15 AM)fdlamotte Wrote: I would love to see a mini usb scope that I could use on my pinephone !
 - usb-c
You can develop on using the Pinecil breakout board.
Great ! I had not cared to dive into the pinecil specs but it seems it has been designed to do more than a simple iron Wink
In the end there is no need for a pineprobe because with the good frontend pinecil would fill that space ...
I was about to buy some pinecones, but I might also add a pinecil and a pinecil bob to the cart ...
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,580 07-24-2023, 03:21 PM
Last Post: Omnios
  Modular product design Zotax 0 881 01-28-2023, 11:50 AM
Last Post: Zotax
  Product Idea: PineTracker EternityForest 0 810 01-12-2023, 10:33 PM
Last Post: EternityForest
  New product idea: Pine Glasses Blathers 2 2,848 12-02-2022, 09:51 PM
Last Post: erikzoltan
  Product Idea: USB Flash Drives barray 104 92,688 09-01-2022, 01:19 PM
Last Post: tarksur
Lightbulb Product Idea: Pine Graphics Tablet israel 10 8,513 04-19-2022, 04:12 AM
Last Post: Houstand345
  Rackmount cluster case as a Pine Store product? dfr 3 3,453 09-30-2021, 04:52 PM
Last Post: poVoq
  E-Note Device (E-Ink, E-Paper, Project Idea) Sirius 9 9,290 08-18-2021, 08:28 AM
  PineVR as a new product? poVoq 11 11,735 05-31-2021, 09:33 AM
Last Post: MirceaKitsune
  Product Hopes for new Rockchip series TailorHouse 11 10,127 03-14-2021, 01:08 PM
Last Post: dsimic
