LCD not working
The LCD/Pine64/SD I received do not seem to work.  I do not have an HDMI monitor or TV so I can only use the the LCD screen to set this thing up. I have tried all the different LCD android images and cannot get the screen to turn on.  I am starting to suspect that the LCD is DOA.
Is there anyway I can verify this?  Should the screen turn on or give any indication of working even without a working SD card?
Any suggestions would be appreciated.
(06-11-2016, 08:05 AM)talvor Wrote: Hi,
Hi talvor
You can use this dd image (burn using win32imager or via terminal on nix; I've liked the smallest dd img - just to verify) or this phoenix card image (remember to set 'startup!'). If you cant get it to boot with either of these / using either method let me know.
BTW: did you connect the screen and TP correctly ?
Can always chase me down on IRC ; if Im not there someone else will help you out
  LCD Panel not working at all treize 7 10,022 09-19-2016, 10:24 PM
Last Post: billjon
Photo Running Out Of Options LCD Panel Just Not Working AUDIOTEK 4 5,074 07-27-2016, 06:34 PM
Last Post: AUDIOTEK
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 5,128 06-13-2016, 08:24 AM
Last Post: PapaStahl
